SOURCE: automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
SOURCE: I have a brother Innovis
Friend,
Please follw the link below for a needle threader for your sewing machine.
http://www.brothersewingmachinesdirect.co.uk/brother-accessories_category-236
make sure the needle is inserted all the way into the needle holder
also make sure the needle is turned the right way in the needle
holder
