Watches Logo
David Blahnik Posted on Sep 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I sent my Fossil watch for a new battery to location in Texas. How can I track it?
Ann Zambetti
Level 2:
New Friend:
  • Expert 30 Answers
  • Posted on Sep 04, 2017
Ann Zambetti
Expert
Level 2:
New Friend:
Answers
30
Questions
Helped
6644
Points
205
Track your package through the company you used to send it: FedEx and UPS typically provide tracking information when you send it, and you can track it with the number provided. If you used USPS, if you selected the tracking option when you mailed it, again, use the tracking number. All these vendors have websites, with clear information about tracking. If you dropped it in the mailbox, you cannot track it.
The Fossil website has information about repairs here Warranty Repairs
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Dec 05, 2007
SOURCE: new fossil watch
It is not likely that there is a protective cover over the battery itself, if there is anything on it to prevent use while not owned it is a little pc of plastic holding the stem out. It is sad to say but there is no way to tell how long the watch had the current battery in it before you received it. It is common to get a new watch and have the battery die shortly after or be already dead. Go to a local jewelry store to have replaced, make sure they are able to test the old one FIRST, if the battery is dead, allow them to replace it, if the battery is fine, return the watch to Amazon.
A
Anonymous
  • Posted on May 18, 2008
SOURCE: how to open the back of a Fossil pocket watch?
battery change
riflemenx
  • Posted on Jun 19, 2008
SOURCE: Fossil ES1592
watch press
Anonymous
  • Posted on Nov 09, 2008
SOURCE: Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Anonymous
  • 103 Answers
  • Posted on Aug 04, 2010
SOURCE: 2 Fossil Watches wont work
fossil watches are very temperamental when it comes to there insides. did you have fossil do the band or someone else? also they sometimes have corrosion from the seals not lasting.
How do I replace battery in Fossil Twist 1114.
You can simply replace battery in your Fossil Twist 1114 watch. First of all you have to open back case of your watch and remove existing battery. Be careful and do not creates scratches on the watch. After removing existing battery from watch you should place new battery in the watch.
2answers
Why doesn't my new Fossil watch ES 4168 work?
Is it still under warranty for repair?
What kind of battery do I need for my watch-Fossil FS3028
Fossil watches typically have an 11-year warranty. If you're still in this time frame, you can send it back to them for replacement at:
SHIP TO: METRO SERVICE CENTER
ATT: REPAIRS DEPT.
10615 SANDEN DRIVE
DALLAS, TEXAS 75238
This is often the only way to get it replaced. If you're not within that time frame, you can try checking a local watchmaker's shop (you can find them in your phone book), and, barring that, you can try a jeweler's shop. But I would suggest sending to Fossil if you're still in the warranty period.
I sent a watch in for a warranty claim in December and have not received one back the number eight had came off inside the face and was floating inside it
You will need to contact Fossil since you sent it in to them. They will be able to help you out. Make sure you have documentation that proves you sent the watch in, or it will be difficult to get the watch back.
http://www.fossil.com/en_US/shop/customer_care/static/fossil-retExchanges.html
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
We bought the Fossil Brown rectangle watch model FS4284, it stopped working so thought it was the battery. we replaced the battery and then 2 months later it's not working again, faulty battery or is...
  • Change the battery. If your watch stops ticking, chances are the watch is not broken and the battery simply needs to be replaced. You can purchase a watch battery at your local department store or drugstore. Use the screwdriver to pry the back off the watch and place the new battery in the same place where the old one fit.
  • Step 2 If your watch is still not working, determine the problem. If you can hear the watch ticking but the hands are not moving, there may be a gear stuck inside. If only one of the hands does not move, the hand itself could be broken. Once you determine the problem, you can see whether it makes more sense to purchase a new watch or get the old one fixed.
  • Step 3 Check your watch warranty. If your Fossil watch came with a warranty that is not yet expired, Fossil will fix your watch if you send it to the company and pay for shipping and handling. See the "Resources" section below to fill out the Watch Repair Form provided by Fossil.com. If your watch strap is broken, however, Fossil will charge you a fee as broken straps are not covered in the warranty.
  • Step 4 Check a competing local watch repair store. There are watch repair stores located all over the United States that will repair a Fossil watch if your watch is no longer under warranty or if you do not want to pay the shipping and handling to send the watch to Fossil's watch repair department. Although the watch repair store may not have the exact strap you are looking for, it may offer a replacement strap that is similar to the one that originally came with your watch.
  • Step 5 Return the watch to the store where you bought it. If you purchased a Fossil watch that was broken when you purchased it or broke recently after you brought it home, you may be able to return the watch for a refund or store credit. Check with the store's policy before purchasing the watch if you are concerned about returns.
  • 0helpful
    2answers
    ES9439 Wrist Watch: what battery doe the Fossil ES9439 Wrist Watch tak...
    Link
    Please visit above link for your Fossil battery requirement. Kindly contact Customer Service Team for further details.
    Thank you.
    My Fossil watch worked when I took it off, it just needed a new battery. Now, I tried to replace the battery, and it won't work
    Check that the battery is in the correct way up.
    Try cleaning the battery with surgical spirit.
    If these steps fail, take it to a watch shop.
    If this also fails, find you nearest Fossil dealer (Fossil/customer care - store locator
    Top Fossil Watches Experts
    john h
    k24674
    ADMIN Andrew
    ADMIN Andrew
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
