SOURCE: please help I have a 1980's model susuki dr 250
I have a 83 DR 250 and i'm not getting enough voltage to create a spark, all I can suggest is that you check your battery and make sure its at full flavour. Check and see if you are getting any voltage prior to the ignition coil (should be 18-35v). If you suspect battery then try clutching it as the alternator moving faster might give you enough to get her going. Also check all your connections and earths. Earth wires are often overlooked and can cause you just as many problems as the actives. So give that a go and get back to me mate. Cheers
SOURCE: skidoo stator.had repaired.now ihave no reverse.
The stator has nothing to do with reverse. The two are in no way connected
SOURCE: I bought a 03 zx-636 that was laid down on the
Correct, the bike will not charge. Aside from that, if the flywheel is actually bent, and it sounds that it is, you will need a new crankshaft and probably a new stator. Without major repairs the bike will never run again. The crank will cost around $650 and the stator will cost around $330 and if the flywheel has been damaged ( it probably has been ) it will cost around $330 as well. The cost for the repair shop will be around $2000 to $3000. The bottom line is that you got taken by the guy who sold it to you. He knew full well the repairs would be far more than the bike was worth. Unless you can get a good engine from a salvage yard, you are pretty much hosed. Google motorcycle salvage kawasaki and see what you can find. I am sorry about the situation. Best of luck to you. Please rate my answer. Thanks.
SOURCE: while riding engine cut out completly. Fuel good
(turn the petcok to reserve , to assure there is fuel flowing)
(make sure the kill switch is in the RUN possition)
turn the key OFF and then back on...
try to retart the bike.
SOURCE: my rm 250 has no spark i have change the stator,cdi box and coil but still no spark
check your plug is the correct spec it should be an NGK BR8EG or compatible.
