SOURCE: set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the
clock/calendar key twice and the time will be diplayed, key in the info
as follows: 12:00pm would be keyed in as "12". "00", the
display will show 12.00 then press the clock/calendar key, the
correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
SOURCE: Setting time & Date
I copied this from another post & it worked for me:
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
SOURCE: HOW TO SET A CLOCK AND CALENDAR ON SHARP EL-1750P CALCULATOR
GT •RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR:
“GT”: Grand Total
“•”: Neutral
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
SOURCE: EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
SOURCE: Sharp EL-1801P III Calculator Setting Time & Date
1. Switch the GT*RATE SET button to RATE SET.
2. Press the date/clock button to display current time.
3. Enter time wanted using military time. 4:52 p.m would be entered as 16.52 (Note the 16 is followed by . then enter the 52. (ie. 10:45 a.m. would be entered as 10.45)
4. Press the date/clock button again to enter new time.
Just reset mine and is current. If the built in battery needs changed, access panel is on the back. It uses a watch type battery.
~DLS
