SOURCE: We have a Coke Cooler (True)-- not cooling, icing over
thes are pretty well built unit, did you check th see is the evaporator fan motor is running at full speed" All that you may have to do is clean the evaporator and maybe change out the evaporator fan motor. True has a special one and you cost should be arouud 75 dollars wholesale.
SOURCE: Avanti wine cooler temperature problem
repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area location.
SOURCE: power supply compatible with cooler master cac-t05-uw
Power supplies are not matched to a case. Any one you buy will fit in the case. You need to make sure it has the correct power capacity and plugs for your motherboard, video card, and anything else you will have plugged into it.
SOURCE: TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MIN.
The unit has a temperature swing adjustment screw located behind the thermostat plate.If you remove the knob and the face plate you will see it,It can be adjusted there.It may also be the thermostat bulb is going bad or touching something and giving a false signal to the compressor.
SOURCE: I have the coleman 40 qt cooler model 5645. The
it is a 60 x 60 x 10 mm 12 volt dc cooling fan available at most computer part suppliers search ebay for 60x60x10mm 12 volt fan
