SOURCE: technics 5 cd changer sl-pd787
Does it show the disc length or any other details? Have you carefully cleaned the lense with a q-tip and some alcohol? Can you hear the laser moving in and out of focus? If you push the laser sled out away from the centre does it move back to the middle when youi put a disc in?
SOURCE: DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
SOURCE: doesn't recornize Cd's and won't play cds
I have a AWM-2700U (3 disc changer) that was doing the same thing. I removed the cover and found that the laser lens for the CD player had come out of it "slot". I cleaned it with alcohol and a cotton swab and replaced it in the slot and it has worked for the past 3 months since. Hope it works for you.
SOURCE: Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
SOURCE: 2005 Lincoln Aviator 5 disc
TRY REMOVING THE RADIO FUSE & WAIT A WHILE. IT SHOULD RESET WHEN PLUGGING THE FUSE BACK IN.
