SOURCE: EL-1197PIII Sharp Calculator
move switch for decimal places to "add",or to number "2" for 2 fixed decimal places
SOURCE: Replacement paper roll size???
Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
SOURCE: Hi I have a EL-1197PIII. I have moved it from my
The "E" is an error indication. If you divide a number by zero that would cause it. But a reset should clear it. Also dead backup battery will cause it.
FIRST replace the backup battery in the unit. There is a small panel on the bottom to access it.
Then do the reset. There is a "poke hole" to reset it that should be marked. Refer to your manual which is also available for free download online.
SOURCE: how do you put the adding machine tape into the
Put the leading edge of the tape into the the opening on the back of the machine. Turn the machine on and press the button with the up arrow, then lift the little metal paper holder and insert the roll.
SOURCE: How do I set the
Hi
Set up > TAB > then select how many numbers you want after the decimal place.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
