Cell Phones Logo
Teresa Thomas Posted on Sep 01, 2017
I have a t-mobile note II SGH-T889 it is pre-owned, i use straight talk as my carrier but never can keep service, where i bought it download a net10 imei number. what would be the right apn settings
5 Related Answers
celltech_adv
Michael J.
  • 443 Answers
  • Posted on Nov 17, 2011
SOURCE: flashing an at&t lg to straight talk service
You can Not do either.
You can't change an imei. and straighttalk will not allow another carriers phone to be used on their services.
Straight talk only uses versions towers. The rest of the company is Tracfone. Tracfone doesn't play well with othere
File Repair Services
  • 827 Answers
  • Posted on Jun 21, 2012
SOURCE: change apn setting nokia 6350
Please refer all the APN settings from the link provided below :
http://broadbandforum.in/bsnl-3g/64177-apn-settings-for-all-network/
Matthew MacWilliams
  • 97 Answers
  • Posted on Sep 05, 2012
SOURCE: how to add apn for sgh a597 on straight talk
AT&T phone on Straight Talk (sprint)? Unfortunately, AT&T uses GSM which is not compatible withSprint's CDMA technology.
Straight talk runs on the Sprint network, same as Boost and Tracphone. Although some phones are the same, some only work on certain networks.
littleobe
littleobe
  • Posted on Nov 03, 2012
SOURCE: changeing apn from one carrier to another?
Jailbreak Then Tetherme Apn Settings
Anonymous
  • 61 Answers
  • Posted on Jan 20, 2013
SOURCE: Unlock My NET10 ZTE Merit phone
Press emergency call in idle mode and input *983*987#, it will go to the factory reset interface and customer can reset the handset to Default.
Note:Please do remember to remind the customer this method will delete all the personal information in the phone.
1helpful
How can I make apn settings?
NET10 operates on either the T-mobile network or AT&T network here are the APN setting for both carriers:
Net10 AT&T APN service
If the one you are running on is AT&T, please enter the following values on the APN:
APN: tfdata
MMSC: http://mms-tf.net
MMS proxy: mms3.tracfone.com
MMS port: 80
Any fields not noted above should be left blank
Net10 T-Mobile APN service
If on the other hand your net 10 service is based on T-Mobile network, use these values instead:
APN: wap.tracfone
MMSC: http://mms.tracfone.com
MMS proxy: Leave in blank
MMS port: 8080
To set the APN go to Settings>More>Mobile networks>Access Point Names>Menu>New
1helpful
2answers
My ZTE net10 GMS is locked, what can I do?
you can get the unlock code for your zte phone from mobile-unlocker.com and unlock your phone from network lock easily.
My won't turn on unless it's plugged into the charger, then it gets stuck on the start up screen
your battery is dead you need to replace it !
if is on warranty go to the dealer before is too late !
or find a place to replace the battery for you ,
do it yourself it's possible but very hard without breaking the little plastic parts !
2helpful
2answers
BLU Studio 5.0 II will not download text message pics.
This is due to your APN settings. I'm not sure which carrier you use, but the problem is generally associated with MVNO companies of the major carriers. This means: Net10, Metro PCS, etc. The Studio 5.0 II does work with all GSM carriers, so this is a plus. It's just a matter of identifiying which one you have, and putting in the right info. You can download the app 'Tweaker' from the Play Store, and it will tell you everything you need. Good luck.
Samsung galaxy note 2 unlock from at&t
Hi, You can unlock a Samsung Galaxy Note II locked to AT&T network safer and easier using unlock code. You can get the unlock code for a Samsung Galaxy Note II from www.wickedunlock.com at affordable cost with easy unlocking guide. Good luck mate.
1helpful
3answers
I need a user's manual for my Samsung SGH-T401G NTT. I bought It from NET10 and it didn't come with a manual.
http://www.samsung.com/us/consumer/mobile/mobile-phones/more-carriers/SGH-T401YKGTRF/index.idx?pagetype=prd_detail&tab=support
Oct 31, 2009 • Cell Phones
Top T-Mobile Cell Phones Experts
Rob Hill
Rob Hill
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
