SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
SOURCE: Elna machanical sewing machine
50 year old elnas made stitches by cams. look to see if the machine has a cam in it. you can see this by opening lid on top of machine. cams are black with red or white showing the pattern of the cam. could also have broken cam stack gear. That would require technician with elna experience
Hi Peggy,
I know this want be easy for you. I need any kind of part number you can get off the LCD screen. Is it a display and you type the different stitch stuff into a keypad? Or , is the LCD a touch screen that you touch the screen to select a stitch? I do not have one of these Sewing machines, but I do Electronics repair. Is your Screen Black and not displaying anything? I believe we can work through this and get you a repair solution. The back light may have gone out on the screen only. Please reply with more info, so that we can get you a solid solution. By the way, Singer really does not make those anymore. They are making a more modern Screen at this time. Usually after 5 years, the manufacturers stop making parts for a model. Good news though, we can work on repairing the one you have. Go to Ebay and see if we can buy a XL1000, or other venue to rob the parts from.
