Washing Machines Logo
E
Evangeline McCalvin Posted on Aug 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water wont come out - Washing Machines
Chris Huff
Level 3:
Top Expert:
  • Washing Mach... Master 6,289 Answers
  • Posted on Aug 31, 2017
Chris Huff
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2019850
Points
74913
If you are referring to water entering the machine, your water valve may be either bad or the screens stopped up.
paul
Level 3:
  • Washing Mach... Master 825 Answers
paul
Level 3:
Answers
825
Questions
0
Helped
174105
Points
2202
Pump blocked........
cheers
1helpful
My washing machine won't fill on cold wash??
The cold water solenoid valve went out. Be sure the cold water valve is turned wide open.
Samsung french door refrigerator wont disense water after replacing water filter
Put the old one back in and if water works, then the new filter is blocked. Buy another filter.......
1helpful
2000 Silhouette: HEATER WONT GIVE OFF HEAT THEIR IS HEAT BUT WONT S...
Check the water level. If the water is low it will not allow water into the heater core to produce heat. If there is water keep an eye on your temperature gauge It should reach at least 140 to 170 degrees. If it is staying colder than that you have a stuck thermostat which is allowing the water to flow to much and not let the engine warm up. The only other solution is if the fan is not working properly replace the fan relay for you blower.
1helpful
Pull cord wont pull
ok i assume it is a gas powered pressure washer, if the pull rope wont pull out at all you either have a locked up motor or pump if it is out and wont go back in or recoil then the spring under the engine cover has either broke or come unwound.also if it wont pull out do youhave water applied to pump? if so turn off water and disconnect water hose to relieve pressure and try to pull it then then if it starts then apply water.
Mar 18, 2010 • Garden
Hot water wont run out on hot water cycle
You mean Run IN dont you?
Water valve faulty.....replace.
My water dispenser wont give water ge #gsh25sgpc
possible frozen water supply tube behind fountain assembly, or broken tube at valve, bad valve, filter,filter mount assembly
1helpful
Wont fill with water, replaced the inlet water valve,still wont fill
First of all make sure the water shut off is on. Second check the water float is it jam on the top position that will shut off the water. then the timer switch that control the water inlet valve.Hope this 'll help. God Bless. have a nice day.
Water wont fill washer. The water currently in
The pump is probably clogged with a coin. Pull off the hoses and check the pump. Make sure you put a pan under the hoses to catch the water
GE Profile Washing Machine wont fill with water top loader
disconnect water lines from washer and check to see if sedement from water plugged up little screen filters
1helpful
Water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
Top Washing Machines Experts
john h
