Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
Posted on Jul 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 02 on a newly installed Bosch Nexxt Washing machine
We just installed our Bosch Nexxt Wahing machine. Ten minutes into the initial trial cycle, we recieved an error code 02 message. I could not find a solution to this error code in the owner's manual. Any suggestions?
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Jul 28, 2009
Anonymous
Contributor
Level 1:
Answers
38
Questions
0
Helped
17743
Points
60
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
MasterTech
Level 2:
Sergeant:
  • Bosch Expert 96 Answers
  • Posted on Nov 15, 2015
MasterTech
Bosch Expert
Level 2:
Sergeant:
Answers
96
Questions
0
Helped
88913
Points
521
The washer is not getting the proper water supply you can learn how to repair this issue here:
http://www.techanswerslive.com/appliances/bosch-nexxt-washer-error-codes-er%3a02/10
Bosch Nexxt Washer Error Code E01
means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
Bosch Front Load Washer Error E01
5helpful
4answers
Error code E:01
Hi and welcome to Fixya, The E01 error for your bosch indicates a door lock problem has been detected at the control board. Insure the door is closed tight, turn your breaker off or unplug the washer for a couple of minutes and retry. Let me know what happens, ultimately it may be a faulty lock assembly, a loose wire harness etc. but we'll cross that bridge when we get there...if necessary. I'll watch for you to respond with the result's. Good luck. Macmarkus :)
E3 error
looks like a heater failure it statrs to heat at about this time into wash mode.
My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
4helpful
Bosh error code E02
Hi. I had the same problem with my Bosch washing machine and called Bosch...was told the same thing...$99.00 for service call. I managed to fix my problem by doing the following:
  • Removed hot & cold water supply hoses.
  • Took filter screens out of both hoses.
  • Removed filter from cold inlet on back of washing machine. I noticed some oily buildup on both of the cold screens so opted to not put any of them back in.
  • Then I put hot & cold water supplies back on the wall hookup, but crossed the lines where they came into the back of the machine intentionally so that the hot water line fed into the cold side of the washing machine and vice versa.
  • Then I ran a couple loads on "cold" which was actually hot water coming in to the machine.
The reason I did this was that I figured there must be some more waxy buildup inside the machine in the cold lines and hoped the hot water would melt it like when you rinse a greasy pan under hot water. IT WORKED!!! I hope this helps you.
Bosch Wahing Machine 300 NEXXT Series
Sounds like a baby sock stuck in the drain. Remove the access door bottom right. Reach in and unscrew drain cover slowly and a little at a time. Put a sheet pan under it to catch the water as it drains. It’ll fill the sheet pan a couple of times so have patients. That’s where your clog will probably be.
Bosch nexxt front koader
If you have had the washer for awhile you should clean the sediment filters, where the hose goes into the back of the machine and where the fascet and hose connect. The cold water side usually collect more sediment. The filter screens are delicate so be careful pulling them out.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
