The OS controls that (microsoft.com covers this fully if your read there)
right click task bar
https://answers.microsoft.com/en-us/windows/forum/all/how-can-i-turn-off-auto-arrange-desktop-in-windows/caae35fa-f5d7-45ef-b953-97d6c235cd5f
bingo 1st google it, millions asked so top hit.
SOURCE: My web camera isn't working.
Check the driver if is still at hes place , if is not there go to manufactor website and dowload the driver
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
SOURCE: flickering screen
Well this may be caused by the inverter board found behind the LCD panel. You'll find a coil on the inverter board. Solder it on the two sides.
The existing solder may be loosening due to heat. Use solder to re-solder the two sides.
Please send us your feedback & vote to help us help you as it should be.
SOURCE: IdeaPad S10e Netbook: CANT OPEN LENOVO ONE KEY RECOVERY UPON START...
Make sure you did it correctly. Computer should be OFF when doing the one key recovery. Turn off the computer then press the small button right beside the power button. Your computer should automatically turned on and you will go straight to one key recovery software. If this will not happen, then the one key recovery is destroyed. We need to re-image your Harddrive to have that one key recovery software back to you computer. You may call Lenovo technical support department for further assistance on how you are going to send your laptop to our depot department.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: My Lenovo ideapad keeps freezing ever since I
If laptop was bought a month ago, it may still be covered by store exchange policy. If so, just take it back to store for exchange. If you bought it with a credit card, it may also be covered by the credit card company for its exchange or repair. Also, if you bought an extended warranty when you did the purchase, it will cover not only repair but also replacement should repair not be possible. Finally, there is the manufacturer's warranty which typically is for one year from the date of purchase but you likely will have to ship at your expense to manufacturer's designated repair site.
If you choose to continue troubleshooting yourself, here are possible freezing causes...
1. hard disk drive has defective sectors (not likely but possible which is why there is exchange)
2. virus infection (pc usually come with a firewall and antivirus which you must activate)
3. conflict between two firewalls, two antivirus or two spyware/malware programs (suppose to only run one of each but often an antivirus program includes features like an internet security suite.)
On the 2nd Tuesday of every month, Microsoft releases a free tool to address virus infections. The tool is called Microsoft Windows Malicious Software Removal Tool. It is usually downloaded in an infected computer's hard drive but if this cannot be done, the tool can be loaded into a USB stick or thumbdrive on another computer then inserted into the infected computer's USB port to be run. Microsoft also has online tools to scan and remove malware. For more information and download go to .... http://www.microsoft.com/security/pc-security/malware-removal.aspx
