SOURCE: Need replacement key set for Casio LK-110
You would need to call casio for such parts or go to a part store which by googling it you can find the parts for this unit.
SOURCE: Does the Casio LK-30 keyboard
No it does not have a sustain pedal input an there is no way to add one, sorry.
SOURCE: I want to transfer some
The keyboard will NOT show up on MY COMPUTER as it does not have memory to record and save MIDI files... It will PLAY them real time as the computer sends the data to the keyboard. You can't transfer and save the files IN the keyboard. Some higher level keyboards do have memory and even hard drives... this one does not. This one will have some built in,that you can play but even those you cannot access as if they were memory.
With the USB cable connected, you should be able to see the device listed in the device manager section of the control panel under system hardware.
SOURCE: the keyboard works fine but
Read your manual regarding "fingered chords" and similar subjects. It sounds like you are in a single fingered chord mode...
SOURCE: what kind of adapter do i use for my keyboard Casio ca-110
if you don't want to wait, you can go to radio shack and get a universal adapter for a bit more, but it should work no problem.
http://www.amazon.com/HQRP-Adapter-compatible-Keyboards-Replacement/dp/B004TXDL3C
