IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs
Use one of the following procedures below to reset the TV.
Procedure 1
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
Procedure 2
Wi-Fi TVs (Smart, Cloud)
Procedure 1
Procedure 2
SOURCE: restore factory settings
You need to do a new windows setup, erasing completely existing system. I do not know if you can do this from Vista upgrade. You may need to install from a bootable Windows setup disk first, and then install vista upgrade. Once you install the system you may need to download drivers. Here is Toshiba drivers page.
regards.
SOURCE: how do i restore to factory settings?
I have researched Toshiba website. They do not list replacement system DVD/CD there. Did find a listing on Ebay but the item was sold. Checked the manual and there is no information on restoration within it. The result is that I do not see any easy answer for you. You could contact tech support @ Toshiba, generally pay for the call and requrest from them the restoration software. Or you could buy XP CD install the CD and acquire from online the drivers for the computer. Regret that the choices are not better.
SOURCE: how do i restore a toshiba L350 laptop to factory
Hello, Bob.
Use the Recovery CDs that came with the system. If you no longer have them, order them through Toshiba. Here's their website:
http://www.toshiba.com/tai/
Hope this helps.
SOURCE: how do i restore my toshiba p300-172 back to
a couple of ways to do that 1) if you have the recovery CDs supplied with the PC - then you can use these - put the CD into the drive and when it boots follow the instructions 2) If you have a recovery partition on the laptop - have a read here to see if you have one http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=recovery+to+factory 3) This link shows you how to use the partition http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2291088&pf=true basically as the PC boots TAP F8 key - from the menu that appears choose "repair your computer"
Testimonial: "tnx i just remembered it never came with a recovery cd but it did come with toshiba recovery disc creator, might give it a try wen i get some cd's."
SOURCE: i want to restore my factory settings but i forgot
use this sir ,1122 or 3344...if no luck ,you need to go to a cellshop and restore it in their infinity box..i guess your h869 is chinaphone..
