How do I change the day but not the date on a Timex Expedition, CR2025? The date is 7/27 but the day says Saturday instead of Monday and I don't seem to be able to access the day.
HI..
HERE IS STEPS FOR SETTING OF YOUR WATCH... STEP3 EXPLAINS THE SETTING OF DAY,DATE.....
SOURCE: Timex chronograph tachymeter hand reset wrong.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: How do I adjust the
Hi, the upper of the two watch stems is turned counter clockwise (looking
at the stem) until the desired function (i.e., format, date, time,
chrono, timer) appears. To set that function, pull the upper stem out
and turn CW to advance & CCW to go back. Once hours & minutes
are set, the stem can be pushed in upon a mark to start at zero
seconds. For the day of the week, turn the upper stem CCW until date
appears. Pull out the stem, to detents or positions, and this will
allow the day to be adjusted.
Take care
SOURCE: need setting instructions for date,alarm,etc on my timex expedition
http://assets.timex.com/manuals/index.html
Here is the link for all Timex watches and the appropriate manuals.
This should provide you with the information you require, if you have an issue not covered there I will try to find you more specific information.
SOURCE: How to set the correct date on a timex expedition
There are several models of Timex Expedition.
The one that has a stem and 4 buttons is set by holding in the set button until the seconds start flashing. The set button is the one that's recessed slightly. There should also be a button for the light and two other buttons. Forget about the light button for now. One of the two other buttons is liks an "advance" button, and the other is the "change" button. If you press the Advance button, the minutes will be flashing instead of the seconds. Us the other button, the Change button, to change the minutes until they are correct. Press Advance again and the hours will start flashing, and press Change to change them. Pressing Advance again will get you to the date, and you use the Change button to change the day and date the same way as you did with the hours and minutes. If you mess up, you can keep hitting Advance until you get back to where you were, and then use the Change button again until it's correct. Once the time and date are set, press Set again to get back to Normal timekeeping mode, and you're done.
If this is the Expedition watch with two stems instead of buttons, you have to use the bottom stem to set the hands, and the top stem sets everything else. Rotate the top stem until the word TIME appears and the time shows in the display. Pull that stem out ONE click to change the hours, then rotate it until the number changes. Then, pull it out more for a SECOND click, and change the minutes by rotating the stem. When done, press the stem all the way back down. The date is basically the same, rotate the top stem until DATE appears, then pull out ONE click and rotate for the month, then pull the stem out a little further for the SECOND click and rotate to change the day. Press back down to save it if you have any further questions message me back and please rememeber to rank how this opinion has helped it allows me to help others in similar situations thanks rick
SOURCE: does the Timex Men's T77862
Here is a link to the Timex support page with the download links for all the different instruction manuals:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
And here is the direct link to the manual for the Expedition Digital Compass model:
http://assets.timex.com/user_guides/W215_M179/W215_M179_NA_EN.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 1 of the manual for instructions which basically read as follows:
1. In TIME mode, press and hold SET/RECALL. Time zone will flash.
2. To set, push + or - to select first or second time zone.
3. Press NEXT. Hour digits flash.
4. Press + or - to change hour including AM/PM. (Scroll through 12 hours to get to AM/PM).
5. Press NEXT. Minute digits flash.
6. Press + or - to change minutes.
7. Press NEXT. Second digits flash.
8. Press + or - to set seconds to zero.
9. Press NEXT. Day of week flashes.
10. Press + to - to change day.
11. Continue pattern to set month, day of month, 12-hour or 24-hour time display, MM.DD or
DD.MM date format, turn hourly CHIME on/off, turn BEEP on/off. If you select BEEP on, a
beep will sound every time you push a button (except INDIGLO).
12. Press DONE to confirm and exit or NEXT to continue and set second time zone, if desired.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
