SOURCE: Homelite
Go to www.homelite.com then in the red up top click on order parts then click launch to parts catalog then scroll down to accept agreement and then you will need to enter your model # and then you can go thru the list of breakdowns and get your part # from the diagrams.
SOURCE: homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of
the line in the hole on the inside of spool.
Wind clockwise onto spool,
putting the line that is closest to the ground on first.
Once you have
winded this piece on, lock the last 4 inches of line through the slits
on spool.
Repeat process for second piece of line, locking the last 4
inches in slot opposite the other locked in piece.
Put the spool on the
trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the
locked position. Put cap on and GO CRAZY!
Jim
SOURCE: Installing new line on my string grass trimmer
Stick the end of
Once you have
on spool.
locked position.
Jim
SOURCE: Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
SOURCE: Can't figure out how to replace the trimmer line
Throw the trimmer spool in the garbage and get a Gator head. It will be the best $20.00 you ever spent.
