SOURCE: Korg TR88 splitting the keyboard.
Read the manual if you've got it. If not get in touch with Korg.com and they should be able to tell you and you might get a manual download.
Good Luck
So you're saying with headphones you also only hear one side? I would suspect the internal amp is panned all to one side. There are also several other settings in this unit where pan can be set so you may have to check several areas. If you don't have any specific custom settings made I would try a restore to factory defaults. If that doesn't resolve it you likely have a hardware failure which is likely not repairable. I strongly suspect a panning issue though.
SOURCE: where can i buy to korg x5d main board
Check the output socket for corrosion, this would stop the sound from getting to the amp. Plug in an output cable and wiggle it around to see if it works intermittently. Plug it in and out a few times and see. We are looking for a dirty connection.
For aproblem of this nature, I would suggest contacting Korg directly. Here is a link to their contact page. Contact KORG
