SOURCE: How do i set up a voice mail greeting on my nortel phone?
bodell,
The short version of getting to your greeting is:
Feature 981 or open voicemail key
your password
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
hope that helped.
SOURCE: I have a Nortel T7208 can't change main greeting
to change the main greeting you need to get into admin programing F983 your also going to need a 7310 or 7324 or a T7316. You have to use the buttons under the LCD screen to navigate after getting into admin press AA
Press GRTG
Press GRTG again
and usually 1 is set for day
and 2 is set for night
press 1 then ok
Press REC.
Hope this helps
SOURCE: how to remove the old corporate greeting in T7316 Nortel?
Press Feature 983 enter admin password
press AA
press Grtg
press Grtg again
press 1 then ok.
Greeting 1 is usually for day and 2 is usually for night depending on the tech who set it up.
SOURCE: I have a Toshiba DKT3010sd. How do I change the main greeting
if the password has not been changed it would be the extension followed by 997, i.e. password for mailbox 990 would be 990997 and 991 would be 991997, you can also log into mailbox 999 and assuming that password has not been changed and is 999997 you could go into admin mode and reset the mailbox security code for 990 or 991, hope that helps.
SOURCE: Nortel T7316E Call Forwarding - Outside Line
The Nortel call forwarding (feature 4) is for forwarding the ringing and intercom from one extension to another.ex. if you were going to be working in the conference rm. instead of at your desk,with the forward on to the conference rm. extension, the calls you get at your desk will transfer to the conference rm. phone. Call forwarding through your service provider is done by accessing the telephone line you wish to forward, dial *72 (you should get dialtone reordered)and dial the telephone number to where you want the calls to be forwarded to. the party on where your forwarding the line to has to answer the line for the forward to take place. to remove call forwarding , access the line you have the forward on and dial * 73, you should recieve a stuttered dialtone for confirmation that the service is off
