Link to Support page for Schwinn Fitness below. There's a link for manuals as well as contact info if you need help identifying your model.
Customer Service
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
SOURCE: battery missing for exercise bike
I have a Schwinn airdyne (model AD-3) that uses a button type battery in the count-down timer, which is above the work load indicator or the 'speedometer'. According to the manual I was given with the bike, it utilizes a 1 1/2 volt watch - type battery (LR44, A 76 or equivalent).
Hope this helps.
SOURCE: Need users manual for old Schwinn Airdyne - analog model
Sheldon Brown's Bicycle glossery is a good place to start, you can google him and he may be slow on replys but he can usally steer you in the right direction.
Testimonial: "I emailed Sheldon Brown. Larry"
SOURCE: Owner's manual for older Schwinn Airdyne
http://support.nautilus.com/support/schwinn/uprightbikes/prdcdovr~3550012/Schwinn+Airdyne+Exercise+Bike.jsp
Follow this link and you can download the owners manual as well as the exploded parts schematics. There will be information about the different years. other than the consoles they have remained the same for 20 + years. If you ever need to replace the bottom bearing be sure to get the lock ring as well. It changed from left hand thread to right. Thats it. You can also upgrade the console to the newer version. A little expensive but with proper care a 20 year old Airdyne will last till the frame rusts out from under it.
SOURCE: I would like to know how to adjust the chain on my
You will need to take the guard off their are 2 drive chain once you do that you will see the adjustments. if you adjusted your bike when you were youg then this is the same
Testimonial: "Thanks, I'll give it a try. Appreciate the input!"
