j
jillianmarie35 Posted on Aug 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Victor 1560-6 is not functioning. When I use the M+ key to store a total and hit the MT key to get a grand total,I get an "E" in overflow mode.Changed the battery -- hit Reset button several times.
richie46
Level 3:
Top Expert:
  • Victor Master 12,962 Answers
  • Posted on Aug 28, 2017
richie46
Victor Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946136
Points
58151
5 Related Answers
A
Anonymous
  • Posted on Sep 04, 2007
SOURCE: Women's Timex Rush Sportwatch
Try holding all of the buttons down at the same time and then releasing them. This should reset the watch. If that does not work, then you need to take the back cover off again and briefly create a short (with a metal screw driver for example) between the battery and the 'brass' casing. Hope this works for you!
Anonymous
  • 35 Answers
  • Posted on Sep 22, 2007
SOURCE: function key lock up
looks like a defective keyboard better return it
Anonymous
  • 9 Answers
  • Posted on Dec 16, 2008
SOURCE: screen got locked
you can try to upgrade the software or at least install it again.
this will solve the problem if it caused by a missing dll related to screen functionality
Anonymous
  • Posted on Mar 06, 2009
SOURCE: Victor 1560-4 calculator
http://www.victortech.com/accessories.asp
109640-01 (Arm Set) for $5.00
Anonymous
  • 133 Answers
  • Posted on Jun 21, 2009
SOURCE: stopped working. battery changed, reset button
Dear Barb400,
You might have tried this already however just wanted to make sure ... Did you try connecting the mouse to receiver .. I mean .. there is a connect button beneath the mouse and there is a connect button on the Receiver that's connected to the USB of your computer .. Did you try pressing connect button on receiver and mouse simultaneously for 2 to 3 seconds and release .. If not then please let me know if this works..
Even if it doesn't work still I would love to hear from you so that I can suggest some other troubleshooting steps.
Hope that works for you :)
Regards,
Srinivas
4answers
Samsung 5200m clear grand total
I HAVE BOUGHT A USED ER5200M. I HAVE CLEARD THE PLU'S AND RE PROGRAMMD WITH MY ITEM & PRICE INTO THE PLU'S. EACH NIGHT AFTER I DO "Z" REPORT, THE REGISTER IS STILL TOTALING MY GRAND TOTAL ONTO THE OTHER OWNERS GRAND TOTAL WITH MINE, HOW DO I CLEAR GRAND TOTAL SO IT WILL BE ONLY MY GRAND TOTAL ?
Clear "M" from calculator
Hit the MT button to bring up the memory. Clear the memory by hitting the "C" button. On the right hand corner above the Tax2 button, you will see where it shows a dot and GT. Move the switch to the dot.
Can't turn off memory
Store zero into the memory.
How can I found out the stats on a Canon NP 6551 (ie total pages, etc...)?
NP6560 Main Specifications
Main Unit
Type: Console
Platen: Stationary
Photoconductive material: Amorphous Silicon
Copying system: Electrostatic transfer system
Developing system: Toner projection system
Fixing system: Heat roller system
Acceptable copy stock: Paper drawer:17 to 24-lb bond (64 to 90 g/m2); plain paper
Stack bypass:17-lb bond to 110-lb index (64 to 200 g/m2); plain paper
(However, Keep in mind that the paper weight that can be used varies
depending on the type of the Sorter being used.
SADF tray : transparencies and labels
Acceptable originals: Sheets, books, and three-dimensional objects (up to 4.4-lb or 2 kg)
Maximum original size: 11" x 17"
Copy sizes: Paper drawer: STMT, STMTR, LTR, LTRR, LGL, and 11" x 17"
Stack bypass: 4 1/8" x 5 7/8" (horizontal placement) to 11" x 17"
Non-image areas: Leading edge: 1/4" (4.5 mm)
Left and right side: 1/16" (3 mm)
Trailing edge: 1/16" (2 mm)
Warm-up time: Approx. 6 minutes (at temp. of 68°F)
First copy time: Max. 2.8 seconds
[LTR size, direct copying, Manual Exposure Control, Drawer 1 (top
drawer) selected 1→1-sided mode]
Copy speed: Direct (100%) LTR 60 cpm
65 cpm (Accelerated mode)
LTRR 49 cpm
11"X 17" 30 cpm
LGL 40 cpm
STMT 60 cpm
STMTR 60 cpm
Reduction 11"x 17" → STMT 56 cpm (50%)
11"x 17" → LTR 48 cpm (64%)
11"x 17" → LGL 40 cpm (73%)
11"x 15" → LTR 48 cpm (73%)
LGL → LTR 49 cpm (78%)
Enlargement LGL → 11"x 17" 30 cpm (121%)
LTR → 11"x 17" 30 cpm (129%)
STMT → 11"x 17" 29 cpm (200%)
Magnification: Direct 1:1.000
Reduction 1:0.500 (11" x 17"→STMT)
1:0.647 (11" x 17"→LTR)
1:0.733 (11" x 17"→LGL/11" x 15"→LTR)
1:0.786 (LGL→LTR)
Enlargement 1:1.214 (LGL→11" x 17")
1:1.294 (LTR→11" x 17")
1:2.000 (STMT→11" x 17")
Zoom 1:0.490-1:2.040
7-8
Paper feeding system: Drawer 1, 2 (1,500 sheets x 2)
Drawer 3, 4 (550 sheets x 2)
Stack bypass (50 sheets; stack approx. 1/4" high)
Multiple copies: 1-999
Power source: 120 V, 60 Hz
Max. power consumption: Less than 2.0 kW
Dimensions (H x W x D): 46" x 25 3/8" x 28 1/2"
(1169 x 643 x 725 mm)
Installation Space (W x D): 40 5/8" x 28 1/2"
(1030 x 725 mm)
50 3/8" x 28 1/2" (1280 x 725 mm)
[With copy tray (option) attached and stack bypass auxiliary tray extended]
Weight: Approx. 462 lb (210 kg)
RDF (Standard equipment)
Originals: STMT to 11" x 17" size (STMT-size cannot be placed horizontally.)
Original tray: LTR 15-lb to 110-lb bond (52 to 200 g/m2)
11" x 17", LGL, LTRR, or STMT
15-lb to 32-lb bond (52 to 128 g/m2)
SADF tray: 11" x 17" to STMT
11-lb to 110-lb bond (38 to 200 g/m2)
Max. power consumption: 120 W
Original tray capacity: Original tray: 11" x 17" or LGL
50 sheets (20-lb bond or 80g/m2)
LTR, LTRR, or STMT
100 sheets (20-lb bond or 80g/m2)
1 sheet
Original replacement speed: 60 sheets/minute (LTR, horizontally placed)
Power supply: 24 V (supplied from main unit)
Dimensions (H x W x D): 6 7/8" x 25 3/8" x 21 1/4"
(174 x 643 x 539 mm)
Weight: Approx. 56.3 lb (25.5 kg)
These specifications are subject to change without notice.
8-1
ar
Energy Saver
Stop
Guide
Additional Functions
Start
Display Contrast
ii
Enter a ID number with the Number ( 1 - 0 )
keys.
MEMO: ? If you make a mistake entering an ID number, press
the C
Clear
key. Then, enter the ID number again.
? You cannot enter two identical ID numbers.
? If you enter and store "000000" in place of a current
ID number, that ID number is canceled.
? You can store up to 1,000 ID numbers.
Press the [OK] key.
If you want to store another ID number, repeat
steps 3 to 5.
5
After entering all the ID numbers to be stored,
press the ID key. The display returns to the ID
entry screen.
6
Canceling the ID Mode: Clearing All ID Numbers
If you clear all the ID numbers then you can make copies without having to enter an ID
number.
Press the Additional Functions , ID , Stop , and Additional Functions keys in that
1 order.
Clear
Guide
Interrupt
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
iii
Press the [OK] key.
MEMO: ? If you want to stop all the ID#s from being cleared,
press the [C] key.
Press the [CLEAR ALL ID#s] key.
Press the [STORE USER ID#] key, then press
the [OK] key.
All the ID#s are cleared.
If you press the [OK] key, you will return to the
Standard mode.
MEMO: ? Storing all the ID#s under "000000" will also clear all
the ID#s.
iv
In the ID mode, the copier keeps track of the copy quantity made under each ID number (up to
999,999). You can view the copy total for each ID number in the touch panel display.
1 order.
After pressing the [COPY TOTALS] key, press
2 the [OK] key.
Press the [?] or [?] key to check the copy totals
for a department. The copy totals can also be
displayed by entering the department number.
Press the Number keys ( 1 - 0 ) for a four digit
department number and it appears at the top of
the display. When you finish checking the copy
totals, press the [OK] key.
Copy Totals (Check Totals)
The following procedure describes how to clear the copy totals for all ID numbers to zero.
Copy Totals (Clear All Totals)
1 order.
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
v
2 the [OK] key.
Press the [CLEAR ALL TOTALS] key. 3
Press the [OK] key.
MEMO: ? To cancel clearing all totals, press the [C] key. 4
The copy totals for all ID numbers are cleared to
zero. If you press the [OK] key the display
requesting the entry of an ID number appears.
MEMO: ? You cannot clear the copy totals for ID numbers
individually.
How do you set the date on a Victor 1560-6 Calculator. I held down the date button on the unit and the number is flashing. I entered 08232010 for Aug 23rd, 2010 and I am not sure of the sequence to lock...
Immediately after entering the year part of the date, the display should revert back to a blinking first digit (in this case, the 0 to the left of the 8) while retianing all the following digits just entered. Simply press the Time/Date key again to lock in that date and stop the blinking. The same process applies for the time.
To clear the display of the time/date when using the calculator to actually compute something, press the C or CE button. This will result in a 0 appearing on the display. The unit is now ready for data entry.
2answers
Show subtotal at finlist
Please try this:- go to PGM-3 select key features select function key- hit sub total see detail functioning of sub total. if you find any link delete it and hit esc.key till you reach in original mode .
8helpful
2answers
INSTRUCTIONS FOR THE KEYS ON THE CALCULATOR
To get a subtotal when adding, finish entering the last number before the subtotal, hit the +, then hit the diamond/pound sign key (just above the 7)
To get a grand total when adding, finish entering the last number in your list, hit the +, then hit the *.
2answers
Victor 1520A Calculator
Coleman and other companies have repalcment add rolls parts, Some are generic and some are original..
Top Victor Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
