SOURCE: Aqualisa quartz shower. Knocking / dripping type
this is caused by the water pressure in the pipes check that all the pipes are secured firmly this should stop the problem a piece of rubber or foam placed behind the pump will also help
SOURCE: Get a knocking noise from an Aqualisa Quartz 2
It may be a water hammering effect from pressure in your pipes. You may need to install a water hammer to stop this. you can put in line that will stop this.
