Question about Razor Toys
I havent used my razor e300 in a couple of years and the button that lights up when it is on is working but the scooter wont do anything.
    Top Expert:
  • Razor Master
  • 12,962 Answers
Betcha the battery is ng!!!!!!!!!!!!!!!
Posted on Aug 27, 2017
SOURCE:
  • 10 Answers
SOURCE: scooter wont work
may be the battery has been damaged. you will have to replace the battery.
Posted on Jul 07, 2009
  • 38 Answers
SOURCE: have an e100 razor electric scooter. it has not
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Posted on Aug 18, 2010
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Posted on Sep 09, 2010
308 Macdade
  • 18 Answers
SOURCE: where is the fuse on
Its the black button next to the switch and charger port.
Posted on Jan 10, 2011
Ironfist109
  • 3018 Answers
SOURCE: how to remove rear tyre from e300 electric razor
  1. With a Phillips screwdriver loosen the two screws and remove the chain guard.
  2. With a 10mm wrench loosen the brake cable anchor and disconnect the cable.
  3. With two 8mm wrenches loosen the brake housing anchor and disconnect. (Keep the spacer and washers together.)
  4. With a 10mm wrench loosen both axle adjusters an equal amount. (roughly five turns)
  5. With two 17mm wrenches loosen the axle.
  6. Push the wheel forward in the slots to loosen the chain.
  7. Pull the wheel out. (Pay careful attention to the order the hardware is in there.)
Regards, Tomy
Posted on May 01, 2011
Testimonial: " that tells me how to remove the weel but not the tyre but thank you anyhow "
Wont start razor e300
On my eZip 1000 scooter, in front of the battery pack, there is a compartment that houses the controller & assorted connectors & wiring. There is also a plastic housing that contains 2 fuses. Check, inspect & test the fuse(s) with an ohm meter for continuity. If all other components are functioning normally, it's probably the fuse(s) that need replacing. Hope this helps.
Oct 02, 2014 | Razor E300 Scooter
Tip
How To Lubricate E100 E200 E300 Razor Electric Scooter Chain Easy Way
<utube src="JKzj7Bu2Ink"></utube>This video will show you an easy way how to lubricate the chain on your Razor Electric Scooter. This process is shown on the E200, it should also be the same on the E300,and E100.
on Aug 03, 2013 | Razor E300 Scooter
Scooter battery how to
you can do anything you want if it is yours . but it may not work as you hope it will
Jul 27, 2014 | Razor E300 Scooter
E300 electric scooter battery,
The scooter uses batteries specifically designed for deep discharge applications. If your new batteries are not lasting then they may only be suitable for standby or backup type applications like for your house alarm system or garage door opener when the mains power goes out.
Mar 19, 2014 | Razor E300 Scooter
Do UPG 12 volt 7ah batteries work as good as "RAZOR BRAND" Batteries?My scooter is an e300.Do you know if by chance,the e300 scooter needs razor batteries only?I got generic ones,and they are terrible
No. We get batteries from a local supplier and they work just as well. are by far the most common problem with razors because people dont keep them charged.
Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Jan 04, 2013 | Razor E300 Scooter
Where is the fuse on a razor e300 scooter?
Jan 08, 2011 | Razor E300 Scooter
Razor e300 scooter charger light stays green, batterys not taking a charge. I can hear a click when turning on throtle. battery or module?
Aug 16, 2010 | Razor E300 Scooter
Need to have manuals e 300 razor scooter,need
http://www.razor.com/products/e300-electric-scooter.php
May 14, 2010 | Razor E300 Scooter
Toys Logo
76 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
