Sony RDR-GX360 DVD Recorder: In Command Mode:(Changes the command mode of the recorder if other DVD equipment is assigned the same command mode.) There are three settings (DVD 1,2 and ,3.) #3 is the default setting and the recorder got switched to DVD1. now the remote won't work and I can't get back to ''menue'' to reset back to default. All I can do is play movies. HELLLP! I've tried everything from unplugging the recorder to useing a different remote. Didn't find anything in the manual.
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Sony RDR-VX530 DVD Recorder: In Command Mode:(Changes the command mode of the recorder if other DVD equipment is assigned the same command mode.) There are three settings (DVD 1,2 and ,3.) #3 is the default setting and the recorder got switched to DVD1. now the remote won't work and I can't get back to ''menue'' to reset back to default. All I can do is play movies. HELLLP! I've tried everything from unplugging the recorder to useing a different remote. Didn't find anything in the manual.
