SOURCE: Need cleaning instructions for ITW Paslode Impulse
I would recommend you go to Paslode.com and under support there is a section for cleaning of these tools. I can tell you how to do it but it is indepth. What kind of cleaning solution do you have? You can't just use anything to clean them. Also the red light on means a failure. Does the fan work? Does it have fire and it also means that the battery is weak. They also have a good troubleshooting section on the site. Let me know if I can help further.
SOURCE: Paslode IMCT Cordless Framing nailer INOP.
yes it will did you test the spark, connect the battery to the tool and push the switch does fan come on?? manually active the safety roller and pull trigger while holding the safety roller does it spark, if so the board is bad, but before replacing look for a loose connection by the trigger on the wires that push onto it. they sometimes come loose. Let me know if you need more assistance.
Testimonial: "I will give that a try--Thanks for the INFO..."
SOURCE: Paslode cordless framing nailer worked
Is your fuel cell empty? Need both the battery and the fuel.
SOURCE: paslode cordless framing nailer doesn't fire
check date on bottom of fuel canister, fuel goes bad
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
