What are the symptoms of bird flu
Very similar to regular flu:
but it is potentially more dangerous and can lead in extreme cases to
So, if you have recently returned from a country that has an outbreak of bird flu (ie Sth Africa, China) and you get flu symptoms, see your doctor immediately.
SOURCE: Bird animation
Right click on it, and select "Save Picture As..."
Leave the file name as is, or change it to anything you want.
SOURCE: Bird Rear-end Size
Hi meduck4,heres what you need brother as I cant see your diff, 3 ways to tell what you have:
#1 The first is the driver's door tag; there will be a
one-letter or one-numeral axle code listed there. You can then compare
it to the chart below:
CODE
Rear Axle Ratio
Conventional
Locking
8
M
2.73
Y
Z
3.08
F
R
3.45
5
E
3.27
6
W
3.73
#2 The second is the axle tag, attached to the lower lefthand bolt on the
rear axle itself. The bottom left line will give you the gear ratio,
and the type of rear end (S for limited slip non-locking, and L for
locking).
#3 The 7.5" rear axle height is shorter than the width and the shape appears "oval".
The 8.8" rear axle dimensions are equal and the shape appears "round".
This will tell you what you have my friend,good luck
SOURCE: Dryer makes noise like a bird chirpping.
You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
SOURCE: Where can I buy spare parts for the Alessi 9093 cordless kettle?
This site seems t0o have the parts yo are looking for ..
Alessi 9093
http://themagazine.info/products/-/167.html
Yes. Sisal rope is
actually a very popular bird toy material.
Here are some great examples of readymade sisal rope bird toys -
http://stores.ebay.com/Tweak-My-Beak/Large-Bird-Toys-/_i.html?_fsub=14787659
http://www.amazon.com/Large-Sisal-Rope-Boing-Bird/dp/B002ISQNLW
http://www.birdcages.com/bird-cage-accessories/bird-toys/braidedleatherstrandsandsisalrope.cfm
Interactive toys are very appealing to birds intellectual
and emotional needs. Here are some more
popular forms of interactive toys:
Foraging toys - teaching birds how to forage for
their food
Comfort toys - something for your bird to
snuggle up to/with
• Hiding toys - some birds enjoy hiding behind larger toys
You should look for non-toxic biodegradable products to help
remove bird waste safely. I use a
product called ****-off Bird **** Remover.
http://www.petco.com/product/12828/****-Off-Bird-****-Remover.aspx
The travel bird cage is usually a smaller version of
a normal bird cage. The travel bird cage does not need to be large, nor does it
need to be as durable as your bird cage. Be sure that your bird can comfortably
fit in this cage for a short amount of time so that it will not become
stressed.
