Http://www.gsmarc.com/acer/iconia-one-10-b3-a40/manual Download the manual and it will show you where the Micro SD card goes.
SOURCE: how to eject a memory card from the 5-in-1 memory card reader on an acer laptop?
jmorgan123 is correct and to make it a little more clear, what happens is when the card is injected in to the slot, you press it delicately until it "seats" in the slot.
To release the card, gently press the card again as if you were to push it further in to the slot and the internal latch will release it, then let go of the card and the spring will let the card loose, then you pull the card out the rest of the way.
If this helps, select the FixYa! ThankYa!
SOURCE: formatting memory card for canon powershot a40 camera
Hi,First format the memory card.
Insert the memory card into the system and this will be displayed as the mass storage device in my computer . Right click over the removable disk and then click format . It will format the memory card .
Hope this helps .
Shane
