Sony STR-DE197 Receiver Logo
Posted on Jul 28, 2009
Sony STR DE 197 Reciever with No Sound
This reciever is only used for music for outdoor speakers. It was left on by accident during a thunder storm and before I could shut it off we lost power. When power can back on it read PROTECT across the screen. Now I do not have any volume...
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
803
Points
I have the same unit. My best recommendation would be to remove all speaker wiring, and try new wiring with another pr of speakers,since the "outdoor " speakers were rained on. the protect mode that the unit went into sounds like it did because the speaker outputs were shorted due to the rain, so ensure that the speaker output terminals are not shorted and dry...also see if output is still availalable at the headphone jack...if it is, the pre-amp section is still good , in which case the protect mode and no volume output out of the speaker jacks may mean that youve blown the ouput trasnsistor finals.
I hope this helps.
bobbymaximus
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
4helpful
2answers
Right front channel not working
try to check balance adjustment if working.
3helpful
I HAVE A SONY RECIEVER STR-DH700, I get no sound
make sure the FM antenna is connected and in a good place then check to see if the A-B speaker selector is selected properly.check to see that the sound field is set properly, My 800 allows for several different options and if your speaker wires are reversed or not in the correct position front left at front left etc it will not send the signal to those speakers. try using the TEST TONE feature if you have one it will send a signal to each speaker in sequence (LF< C< RF<in order) it will go all the way around to see if they are connected properly, that way you can tell if they are connected at all or in the wrong spot on the back interface. I dont know if that is what you meant by AUTO CAL, but that is a seperate feature when you use the connected mic to determine range, height and distance to the position in the room you are most likely to be seated for optimal sound.
I have a STR DE 485 reciever. When I try and turn
unplug,leet capacitors discharge, check back of unit where speaker wire clips are to make sure there are no wire strands touching each other,check same thing @ speakers, try turning unit back on.
1helpful
Low sound at high volume
THe problem is with the variable resistor present behind your volume control knob, try replacing the volume controls variable resistor, this must work fine... this is a common prblem for all the music equipment that has knob control for the volume....
This resistor can be replaced with your product warranty, contact your seller for the details regarding warranty...No need to woory about this, this is a sommon problem for most of recievers
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
1helpful
Sony str de405 receiver...was working fine, now no sound
I have a problem with vintage reciever Sony STR-11L. Power transistors were replaced and I dont know what were original ones. Sound is no good and radiator is hot-I think problem is in replacement. Can anybody help me with?
Sony amplifier STR DA2000ES protector code 22
go to your manual and repeat connection and setup and try with new cables because may be the cat bite something hidden from your eyes.
2answers
Can't get surround sound when watching tv
your RCA on your tv is acting like its in mono..it may be a problem with the jacks.  alternatively..you can buy a splitter and split teh side that sounds stronger (L) or (R) with a male to 2 female spliter out of the tv then back into l/r input on your reciever... It wont give you surround stereo...but it will soudn a whole lot better.
3helpful
2answers
My reciever does not work
Power Amp IC gone in your set, replace it.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
