SOURCE: TOM TOM WON'T NAVIGATE
Reset your device
Reset your TomTom using a straightened paper clip.
If you use a PDA, check the manual that came with your PDA to see how to reset it.
Install the latest application
We recommend always having the latest version of our application installed on your device.
See also: How to check for and install an updated version of the TomTom application?
SOURCE: my nextar won't do anything'
Hi fishwork2,
Have you tried resetting the unit. The easiest way to correct any issue with this unit is by resetting it. Here's how will you do it.
1. Press the power button on the front of the unit for about 20-30 seconds. Wait until the logo screen shows up.
2. It takes about 50-60 seconds total to restart. Don't worry because the contents including the registry will be intact after it reboots.
Hope it helps.
Thank you for using FixYa.
Hi
You did not mention which gps systems do you have. Anyway giving you details of tom-tom gps language change instructions.
Change the language settings on your TomTom GPS device. If your TomTom GPS receiver is set to the wrong language, change the current language to the language of your choice. Perform a reset on the device as described in Step 1. When your GPS unit turns back on, tap the button in the lower right corner of the screen to continue. Tap the next screen to access the GPS receiver's main menu. Tap on the wrench icon to access the "Change Preferences" setting screen. Scroll through the "Change Preferences" screens until you see the "Change Language" icon, identified by three flags. Tap the "Change Language" icon and choose your desired language from the list. Depending on which language you chose, you may be asked to choose a new voice for turn-by-turn navigation.
For Garmin device:-
Try this below
Touch the Wrench icon which is located on the screen with the Magnifying Glass and Map icon
Touch the down arrow
Touch the Lips/Mouth icon
Touch the top right blue box
Touch the up arrow until you see American English
Touch American English
Touch OK
This should now be in English.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
