SOURCE: I have a refrigerator model
ctx14cys**** the 14 is a give away, it would be a ctx16 if 16 cube. heres a sire just pop in the model number ittl clearly stae it, ifthe link doenst work, i went to www.ge.com, ad nfound it through there
http://genet.geappliances.com/DocSearch/Dispatcher
SOURCE: Chefmate RS-06DR mini Fridge (1.6 Cubic Feet)
My chefmate is **** because the internal fan is garbage, its cheap, it
doesn't work or give enough flow, try a higher flow unit. You can get
the 12v at tigerdirect.com with some high flow (AND LIGHTS :) ) for a
few bucks to save your 100 dollar investment. The removal of the orig
fan is easy. The evap is a good setup, but the cooling setup for it
seems to be sh*t. Cheap fans = cheap setup and this is why everyone
hates these units cause it can't pump the goods.
For the record my fan died, so my evap and fan froze over completely
and spoiled my food and burned out the fan completely and probably
helped to short it. I can get it going if I flicker the fan with my
finger but she is dead and can't catch naturally. You could replace the
chefmate fan with most computer fans too... fyi if you got a junk tower
laying around.
While your at it clean the fans on the back and take off the back panel
which kicks out the hot air from the hot flow. It helps if your unit is
older (a year plus+ in a dorm is like 4 in a clean house lol)
SOURCE: We have Maytag 25 cubic feet stainless steel
There is a defrost problem. Ice builds up between the ref and frz sections and wont allow coolo air through. You can also check to see if the damper is stuck closed
SOURCE: Cubic feet in a GE MOdel TFX22KRCE WW
If there is nothing inside the refrigerator that will tell you its cubic feet, you could always calculate it on your own. See this link:
http://www.ehow.com/how_4530599_find-cubic-feet-refrigerator.html
SOURCE: how many cubic feet is my ge fridge, TFX25JP?
The first few numbers in the model number indicate the cubic footage...so that refrigerator is 25 cubic feet
GENE
