SOURCE: fuse box
The main fuse is under the panel on the right side behind the forks and the rest of the fuses are in the crank case under the cover...where you fill the oil.
SOURCE: Suzuki intruder 1500 charging system
You need to buy a volt meter and set it on 10, or 20 v-. Start the bike and see what it says. A good charging system will show 13-14+ volts. If the meter says 11-12 volts or does not change, you have a bad stator, or rect/reg. Take to a shop to have it further tested. Chaz Moto DC
SOURCE: 2002 VL 1500 Intruder LC: What is the proper tire pressure for Suzuki vl 150...
Tire pressure is 29 lbs for the front and 36 lbs for the rear
SOURCE: I have Suzuki VL 1500 Intruder bike. The clutch
http://www.bikebandit.com/2004-suzuki-motorcycle-vl1500/o/m6819#sch502265
Here is a schematic, parts list, and prices for your 2004 VL 1500. Friction disks wear out and have to be replaced at regular intervals. Clutch slipping is almost always remedied by replacement of the friction disks.
SOURCE: how to adjust clutch 1998 Suzuki VL 1500 intruder
The clutch on this model is hydraulic and is 'self adjusting", if the clutch is slipping the plates are worn out and in need of replacement. This information comes directly from the factory service manual.
