Garden Logo
t
tammy Posted on Aug 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Stanley model 425605x692b riding mower. runs very slow. runs fine otherwise. any way I can speed it up?
richie46
Level 3:
Top Expert:
  • Stanley Master 12,962 Answers
  • Posted on Aug 25, 2017
richie46
Stanley Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2945952
Points
58151
Is tranny and various speeds working properly? How about the throttle control? Do you have it set for higher speed?
5 Related Answers
Anonymous
  • 36 Answers
  • Posted on Nov 29, 2008
SOURCE: 2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Anonymous
  • 1489 Answers
  • Posted on May 01, 2009
SOURCE: BOLEN RIDING LAWN MOWER 13AN683G163 TRANSMATIC
Either the belt routing is incorrect or there is a tensioner which needs adjusting. Recheck your belt installation. Oh, it could be the wrong belt, too.
wadembly
Wade Mobley
  • 513 Answers
  • Posted on Jun 05, 2009
SOURCE: i need a repair manual for a scotts riding mower.drives a few fee
it could be the axel they have spider gears in them & the teath could be sheared or the the rearend is low on fluid
Anonymous
  • 396 Answers
  • Posted on Oct 10, 2009
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Anonymous
  • 33 Answers
  • Posted on Apr 14, 2010
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Stanley rideing mower
well should of mentioned the model number that you too can goggle
Oct 18, 2014 • Garden
2answers
Why would a riding mower have the blade turning slow?
If speed varies depending on how much grass you are cutting, look for loose or badly worn belt. If constant slow speed when engine is running at full noise can only be a slipping on pulley or clutch. Most likely clutch. Normally slipping generates much heat so look to your clutch or pulleys. If drive key has separated there will be damage to shaft with metal dust showing.
Jul 21, 2014 • Toro Garden
2answers
Stanley riding mower wont start but gettin fire and fuel
its getting fuel to the carb but is the solenoid working on the bottom of the carb they stick and also safety switches go bad and kill the power going to it
May 28, 2012 • Garden
I have a model yth2348 mower. How do you adjust the speed of the mower. I have changed the drive belt but it still runs slow.
hydrostatic transmission there is only one throttle setting and that is WFO. if it is running slower than it used to, and the drive belt is snug, then you are looking at a failing transmission.
When mowing in heavier grass engine loses power. Starts fine and runs fine otherwise.
Raise your deck in high grass, sharpen your blades and turn the throttle up to full speed captain. Check your belts. Good Luck...
Jun 04, 2011 • Garden
Speed of tractor slows when I run for more than 10 minutes. It will not climb a small incline after it gets hot. I can let it cool for a half hour, then it runs fine untill it gets hot ,and eventuall will...
you need to call a dealer and get a price to replace the transmission. perhaps you can swap yours for a rebuilt tranny. If you are at all mechanical, you can change the transmission yourself in an afternoon, so some cost could be saved on labor.
1helpful
The mower moves slow in all speeds what is the problem
If the engine is running well you either have a loose drive belt or the transmission is on its last legs.
1helpful
2answers
Bagger problems
I need the shoot for the mower bages
Aug 11, 2009 • Garden
1helpful
My riding mower workes fine fore about 45 mintes then it slowes down wants to move real slow and wont pull my yard sweper anymore. The blades engage just fine, the motor starts/runs fine It just moves slow...
Im assuming the tractor is a hydrostatic, in this case when the transmission starts to go...thats it, call the company and find a replacment or get another tractor. unfortunately rebuilding them isnt all that worth it
Top Stanley Garden Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Stan Ford
Are you a Stanley Garden Expert? Answer questions, earn points and help others
