This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Bad solenoid where water goes into the dishwasher. follow the tube from the water pipe in your house to where it goes into the dishwasher. turn off the power to the dishwasher. the small plastic pump(solenoid) where the tube from the house goes into the dishwasher is what you need to change. It has one electrical plug, two hoses attached, and a couple of screws holding it to the frame. remove the plug, the hoses, then the screws. Take bad solenoid and model number of dishwasher to hardware store they should be able to help you get the right one.
sound to be in heat modenow. If you are after the cool mode, then if you have a cool setting and a heat temp setting, Lower the heat to almost off and set the cool setting to 74 degrees. See if the outside coils get warm. Make sure you are off manualo and n auto. If it runs, give it some time and the tenp of the outside coil will rise and the inside will get cold. Food Luck
