SOURCE: amana side by side ice dispenser leaking water
Take the ice maker out and look at the mold. If the coating is flaking off then that is where it is leaking. Will need to replace the ice maker.
SOURCE: ice build up
There may be a drain tube for the frost free located in the panel behind bottom drawer. The drain tube sounds to be full of ice. You will need to remove all items from freezer and use a hair dryer to melt the ice fully. Also remove the cover panels so you can tell when you get the drain unplugged. Pour hot water down to make sure the line is melted and free of other pluggage.
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
SOURCE: ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
SOURCE: refrigerator is leaking water into drawers and out on floor
Your defrost drain is clogged . Remove the rear freezer panel and using a hair dryer , defrost the aluminum tray below the coils . When you see the drain hole , defrost it and use a small tube to insert and blow thru to remove any possible "gunk" . You may have to use a little hot water to help defrost the drain , but keep at it until you can blow thru it .
