SOURCE: Text Message Inbox setup
you must insert the message center number in the message settings(setup)....
to get the message center number follow the steps below...
1. call to your network provider customer care
2. ask them for the message center number
3. note down the message center number
4. insert that message center number in the message settings
and save it...
one this completes it will not ask you for the setup while sending messages or when you open the inbox..
any doubts reply me..
i am always here to assist you
thank you
bye....
Dnt forget to rate the solution........
SOURCE: don't receive incoming text messages.
Call your carrier's tech support, they have to re-setup your plan. In the end, it will either come down to doing a hard reset on your phone, a ticket, or replacing the phone.
SOURCE: 3g not working on apple Ipad
As far as I understand it the ipads that have just been released are wifi only. 3g are available from late April, see the www.apple.com for details.
SOURCE: Aloha! i just got a new ipad and would like to
You can sync apple ipad with outlook, there are different ways to do this, I will show you way where you can sync between your Google calendar outlook and your ipad.
Please follow the next steps.
* If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
* Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
* Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
* Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
* Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
* Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
* A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
That's about it now your ipad is synced with outlook through your google calendar.
Hope this will help you with your problem syncing ipad with outlook
SOURCE: I can't get my linksys to conntect to my apple
You will need to try and connect to a WiFi network.
When you use any Internet-enabled application, iPad does the following, in order, until connected:
-G33k
