This problem is sometimes caused by a leaky injector. The system bleeds down overnight and takes time to repressurize. You would have to pull up the fuel rail to check for leaky injectors.
Although the cause of idiopathic leg cramps is unknown, there are a number of theories about what might cause idiopathic leg cramps. These include:
abnormal nerve activity during sleep which causes the muscle of the leg to cramp
excessive strain placed on leg muscles, such as when exercising, may cause the muscles to cramp at certain times
a sudden restriction in the blood supply to the affected muscles
Also, tendons naturally shorten over time as a person gets older, which may explain why older people are particularly affected by leg cramps. Tendons are tough bands of tissue that connect muscles to bone. If your tendons become too short, they may cause the muscles connected to them to cramp. Secondary leg cramps
Secondary leg cramps are caused by an underlying condition or another identifiable cause. These include:
pregnancy: the extra weight of pregnancy can place strain on the leg muscles, making them more vulnerable to cramping
exercise: leg cramps are often experienced when resting after exercise
There are no reported side effects and it has been awarded a GRAS (Generally Regarded As Safe) classification by the US FDA. At very high doses (40-50mg/day) you might encounter slightly pink-red hued skin as levels of the supplement build up and redistribute.
Sounds like you have many more than just one problem. It really doesn't pay to throw a bunch of parts at a problem and hope it's fixed. The climate control head display shutting of and coming back on at 75 degrees is most likely due to a bad Central Power Module, a common problem in older Toronados. Hard to find, not too hard to replace. It's under the dash to the left of the steering column. The no spark problem could be any of several things. Did you check for good cam and crank sensor signals? Do you have spark at the plugs? Have you changed your plugs wires? Do you have any stored codes? If the console says there is an electrical problem, you can be assured that there is indeed an electrical problem somewhere. It may not have been severe enough to cause a concern for the past seven years, but it may be worth taking a look now to see if has anything to do with what going on. Replacing the oil pressure sensor is easy enough and inexpensive enough as a first attempt to fix the gauge readings acting funny.
sir please help me my mother and father is dead , i dont know whats up this situation my huband reports its correct i am second wife his ,his x wife have one child, my problem its i want pregant last time i have email you , u ask me your reports its perfect know you should be show the husband reports , my husband do test and its perfect result , i had conceive two times but unfortantly just 2 week and then started the bleeding last month i had conceive it , bleeding started 2week after i do dnc, my doctor suggest ,you rest one month birthcontrol pills i have completed the course she ask me you started the 2nd day of periods started the cerophene 50 mg 7day of periods and then ultrasound 12 day "5 tablets or 6 i take and please suggest goods doctor, i hope you help me. thank you quratulain ahmed [email protected]
For the A/C relay, under the hood, the relay box should be on the passenger side right near the window wipers, open the panel and check for the relay fuse. The main relay is in the car under the dash right by the drivers left leg.
If you are sure that it is getting fuel,,,try taking a hair dryer, turn it onto high heat setting and just prior to cranking the motor and during(will take two people) force the hot air into your Air cleaner intake. Usually getting the motor good and warm with any means you can think of will solve the starting problem. But since it has been sitting for several years,this may be just the beginning of your adventures.
