SOURCE: need a kawasaki zxi 1100 owners manual
Most of the time you can look up the owners manual on websites as long as you can find the kawasaki website you should be good, i had the same problem with a dirt bitke and i found there website and found the owners manual and downloaded the owners manual and printed it out. Hope i was of some help to you.
SOURCE: 2001 sts 900 kawasaki jetski wont start
Check the engine compression with a compression tester. It should be over 100psi,also check for hot blue spark on plugs,if not blue ignition problem.Weak Spark,but if blue and wont fire with ether the rings maybe worn,and compression to low...Best of luck to you!!!!
SOURCE: fuel mix in jetski is to oil rich need to lean out
Jet ski's do not have an adjustment on the oil pumps unless they are cable operated. Most just run off the end of the crankshaft. If the machine sits for a while and the oil pump seal is leaking. Oil will collect in the crankcase and take a few minutes of running to clear out. You can live with this, replace the pump, or block off the pump and pre-mix. A popular, cheap solution but a pain when it comes to refueling. As for the lack of power you probably have water corrosion in your carburetor nothing a simple cleaning won't cure.
SOURCE: I have a 1998 Kawasaki kx 250 and there is fuel
it sounds like the float,in the carb is stuck,,so not stopping fuel as it fills.....give it a tap on the bottom of the carb if no joy take off and clean,,,
SOURCE: kawasaki just won't start new plug in still won't start plug gets wet any help please
check for spark
