Swimrite heater I believe 3.5 tons. I cannot find my manual and do not remember what to do to reset this code. Thank you.
Are they the ame size? Have you looked all around it to see either an IN or OUT stamped into the plastic. Usually the out is on the bottom of pumps it depends what type. This is a heater pump so be careful. The stamp in or out should be on the sleeve itself where the hose slides on. Good Luck. Sometimes its just a hit and miss.
Testimonial: "There are no stickers or stamps that say inlet or outlet. Both pipes are at the same level coming out of the bottom of the heat pump."
