Televison & Video Logo
Durabrand DVD model 1002 power button is red but no function?
4 Related Answers
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on Jul 17, 2009
SOURCE: portable durabrand dvd wont read disc
If it is reading a burned movie from the internet make sure you set you brun software for captability mode.
If this is a orginal disk make sure its free of dust and scratches.
1. buy a lens cleaning kit from walmart or any other eletronics store.
2. Make sure the disc is free of scratches.
3. change disc's and see if it works on any others.
if these steps do not help then the laser would need to be replaced. Durabrand is a Wal mart brand i had mine for 2 years and i had to clean the lens 3 times with a cleaning kit.
Thanks
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
ohms
monk3ybidzness
  • 1879 Answers
  • Posted on Sep 07, 2009
SOURCE: will not read disc
better get a new one
gopakumarg43
  • 76851 Answers
  • Posted on Nov 16, 2012
SOURCE: can durabrand function with dvd?
What is the exact model number to your Duraband TV? Without this detail, how can one post a solution to your problem?
gopakumarg43
  • 76851 Answers
  • Posted on Aug 23, 2017
SOURCE: Durabrand DVD model 1002 power indicator button is red but no functions?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
After playing, dvd unit smells and quits playing. Saw online that there was a recall on ones bought at Walmart. I purchased at walmart but they said to contact Durabrand.
Recall on certain models of Durabrand DVD:
Pink: UPC 1799934100, Model No. 1002 PINK
Silver: UPC 1799901002, Model No. 1002
Purple: UPC 1799932100, Model No. 1002 PUR
https://www.cpsc.gov/Recalls/2009/wal-mart-announces-recall-expansion-of-durabrand-dvd-players-due-to-fire-hazard
2answers
Need manual for Duraband DVD 1002 D seri
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 – 5 – 9 – 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Manual
I need the manual for the Durabrand DVD Player Model 1002, where can i get one, I got the DVD player at a Thrift store
Durabrand DVD Model 1002
This product isn't being supported anymore by Walmart because the manufacturer Lennox Electronics went out business in December of 2007.
Here is a report on it:
http://www.ripoffreport.com/reports/0/335/RipOff0335691.htm
Dvd video player
which the value of de diode zw1 of dvd 1002 durabrand
Dvd wont play
the Durabrand model dvd-1002 is not a blu-ray dvd player. It can only read the regular non-bluray discs.
Power cord
try this one.
LINK
or try radioshack they can hook you up with an universal which will work just as well.
Good luck
Durabrand DV 1002
on your remote there should be a display button push it and it should tell you how long into the movie you are
Durabrand dvd
you will need either a scart leed or a set of colour leeds usuall red yellow white plug these itno your player matching the colours up then in the back of your telly you should have the same colour conectors plug these in then press the av button on your telly this should pick up the signal hope this helps you
Top Durabrand Televison & Video Experts
matt martin
matt martin
ZJ Limited
ZJ Limited
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
