Computers & Internet Logo
Ntsekiseng Currence Posted on Aug 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NG: LCRSLSRBLBR - Computers & Internet
Marvin
Level 3:
Top Expert:
  • Computers & ... Master 85,242 Answers
  • Posted on Aug 23, 2017
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29057686
Points
266281
NG: LCRSLSRBLBR?? What is this?
I changed my coil pack and now my car won't idle it's a 2002 Mercury Sable 24 valve
C? n?n ch?n k? tivi treo t??ng b?y tr? ? ph?ng kh?ch ?
Xu h??ng hi?n nay ch?nh l? b?y tr? nh?ng chi?c k? ??c ??o, m?i l?. H?y c?ng ch?ng t?i t?m hi?u v? c?c lo?i k? tivi treo t??ng ? ph?ng kh?ch nh?.
N?u b?n s?ng trong m?t kh?ng gian ch?t h?p? B?n lo l?ng li?u c? ?? kh?ng gian khi b?y tr? tivi ph?ng kh?ch th? ngay t?i ??y nh?ng chi?c k? treo t??ng s? gi?p b?n gi?i quy?t ?i?u ??! th?ng qua website https://kozyhome.vn/danh-muc/ke/ke-treo-tuong/ c?a ch?ng t?i. B?n s? t?m ???c cho m?nh nh?ng m?u k? ?ng ?. Kh?c v?i nh?ng m?u k? ??ng hay k? treo t??ng tr??c ??y. M?u k? treo t??ng tivi gi? ??y ?? ???c ph? c?ch ho?n to?n, n?u kh?ng ?? ? k? b?n s? kh?ng th? nh?n th?y ???c ch?ng. B?i ch?ng ???c thi?t k? g?n ch?m v?o trong t??ng sau ?? ???c m? r?ng kh?ng gian ra b?n ngo?i trong m?t khu v?c, di?n t?ch nh?t ??nh.Vi?c s? h?u nh?ng chi?c k? tivi treo t??ng ki?u n?y nh? m?t ph?n c?a phong c?ch trang tr? ng?i nh?, ch?ng mang l?i nhi?u gi? tr? th?m m? cho ng?i nh? c?a b?n. C?ng ch?ng t?i c?p nh?t nh?ng tin t?c m?i nh?t qua nh?ng trang m?ng x? h?i https://www.quora.com/profile/Ke-KozyHome
Ch?ng gi? cho ng?i nh? c?a b?n ???c ng?n n?p t?t h?n ??c bi?t v?i nh?ng khu c?n h? khi m? di?n t?ch c? h?n. S? h?u k? ?m t??ng ph? h?p trong nh? c?a b?n, b?n s? c? ???c kh?ng gian t?t h?n cho nh?ng ng?i nh? nh? ??ng th?i gian ph?ng kh?ch c?a b?n s? tr? n?n ??p, ??c, l?, g?y ?n t??ng v?i nh?ng v? kh?ch ngay t? c?i nh?n ??u ti?n.
Tuy s? h?u m?t s? ?u ?i?m l? v?y, nh?ng nh?ng m?u k? tivi treo t??ng v?n c? m?t s? h?n ch? m? b?n ph?i l?u ? tr??c khi ra quy?t ??nh mua ch?ng
Vi?c ??u ti?n ?? l? ph?i ph?i ch?n k?ch th??c chi?c tivi ?i sao cho ph? h?p v?i chi?u d?i, chi?u r?ng c?a t??ng ?? khi ta ??a tivi v?o kh?ng qu? to v? c?ng kh?ng qu? nh? ph? h?p k?ch th??c ph?ng kh?ch
Sau khi x?c ??nh k?ch th??c t??ng vi?c ch?ng ta ti?p theo ?? l? x?c ??nh chi?u r?ng, cao ,?? d?i c?a tivi ?i ?? c? th? thi?t k? sao cho cho tivi khi l?p v?o h?c t? th?t g?n kh?t v? ??p m?t. ??y l? m?t ?i?u r?t quan tr?ng ??i h?i ph?i c? nh?ng nh?n vi?n c? chuy?n m?n k? thu?t ch?nh x?c n?u kh?ng s? c? tr??ng h?p h?c t? b? v?nh kh?ng vu?ng g?c, kh? kh?n trong vi?c l?p ??t tivi. Tham kh?o th?m https://blogfreely.net/kekozyhome/
Khi l?p gh?p k? tivi treo t??ng kh?ng th? thi?u ?? ch?nh l? c?c khung treo, m?t chi?c khung ph? h?p s? gi?p tivi c?a ch?ng ta ???c c? ??nh ch?c ch?n h?n. Ngo?i ra b?n c?ng n?n l?u ? thi?t k? c?c h?c t? ph?a sau tivi c?ng nh? trang b? ??y ?? ? c?m ?i?n ?? s? d?ng m?t c?ch t?t nh?t.
Pioneer VSX-1131 NG:LCRSLSRBLBR Detect Protect:I Was listening to music and then this popped up. It’s 2 years old so no warranty. I’ve tried to reset it, goes into diag mode and then same error. ...
Your Pioneer unit has gone into protect mode because of component failure. Use your multimeter to check continuity and voltages at the component level. Also check for cold solder joints.
I cannot resolve the Pioneer VSX-1131 error code after multiple troubleshooting attempts: NG:LCRSLSRBLBR
Hi, what the error code is telling you, NG: LCRSLSRBLBR, is that due to some output problem or power supply, the speaker outputs are not working, NG by Non Good, L by Left, C by Center, R by Right, SL by Surround Left, SR by Surround Right, BL by Back Left and BR by Back Right
I suggest you check all speaker connections, disconnect all speakers and see that this is the same, the problem is in the computer, if it does not indicate failure, then go connecting the speakers one by one until the fault appears again and in that last speaker connected, the fault could be, try all the speakers
I hope you can solve the problem, but look for a specialized technical service
Greetings Franco Dosil
Hola, lo que te esta indicando el c?digo de error, NG:LCRSLSRBLBR , es que por algun problema de salida o fuente de alimentaci?n, no est?n funcionando las salidas de parlante, NG por Non Good, L por Left, C por Center, R por Right, SL por Surround Left, SR por Surround Right, BL por Back Left y BR por Back Right
Te sugiero revises todas las conexiones de parlantes, desconecta todos los parlantes y observas que esta igual, el problema esta en el equipo, si no indica falla, entonces ve conectando de a uno los parlantes hasta que te aparezca nuevamente la falla y en ese ultimo parlante conectado, podr?a estar la falla, prueba todos los parlantes
Espero puedas resolver el problema, sino busca un servicio t?cnico especializado
Saludos Franco Dosil
How to fix NG LCRSLSRBLBR ON MY ONKYO TX NR55T
Hello
There are a lot of customers having the same issue.
It is a manufacturer defect.
Sorry for you.
Error code NG:LCRSLSRBLBR on Onkyo TX NR555, solution please
Same situation as this. V means DC protection.
http://www.fixya.com/support/t26859458-need_help_onkyo_tx_nr636_cuts_off_as235c75ae-0611-4ecd-b799-2e12c2784c09.jpgforum-zzw53jh0vnu5wdtpskq2i21s-4-2.jpgforum1 -zzw53jh0vnu5wdtpskq2i21s-4-3.jpg819279_200_200-12hrymc5q4xy5bipfulaagnc-1-3.jpg819280_200_200-12hrymc5q4xy5bipfulaagnc-1-5.jpg819279_200_200-12hrymc5q4xy5bipfulaagnc-1-4.jpg
3answers
My onkyo tx-rz810 keeps going toDet.pretction mode how do I get it out of that mode
Does the display show you are in protect mode , or is a light indicating that? The unit automatically switches to standby when the
"Hardware" - "Power Management" - "Auto Standby"
setting in the Setup menu functions are set. The protective circuit function may have been activated.
If this has occurred, "AMP Diag Mode" appears on the
display when the unit is turned on again, and the unit
enters diagnostic mode. If the results of the diagnosis is
that there is no problem, the "AMP Diag Mode" display
disappears and you can use the unit normally again. If
"CHECK SP WIRE" appears on the display, the speaker
cables may be short-circuited. Make sure bare speaker
wires are not touching each other or the back panel of
the unit, then turn the unit on again. If "NG" is displayed,
immediately unplug the power cord from the wall outlet
and contact your dealer.
• The protective circuit function may have been activated
because the temperature of the unit rose abnormally.
If this happens, then the power will continue to turn off
after you have turned the unit on again. Make sure the
unit has plenty of space for ventilation around it, wait for
the unit to cool down sufficiently, and then try turning it
on again. This is out of your users manual.
General suggestions are to remove all speakers and speaker wiring with unit off. Turn on and see if problem has stopped. If not, let unit cool down if warm and try again later. If problem is still there it needs repair shop work. I fht problem went away, shut off power and connect one speaker at a time and testing. Keep adding speakers one at a time with power off and see if a bad speaker or wire set can be located
Onkyo tx nr656 showing. NR:LCRSLSRBLBR, Any idea. Not working at all.
Hello, I am sorry about your issue. The receiver may have detected a problem with a speaker or speaker wire. Please contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
After moving, I was hooking up an onkyo tx sr444. I got an error message ng:lcrslsrblbr. I haven't had very good luck with shipping it back, so I started looking around and asking folks like you.
Hi Rex, I am sorry that you are having an issue. Please send me an email to [email protected] .com and I will send a procedure that will possibly resolve your issue. Thank you, Onkyo USA
2answers
What is error code NG:LCRSLSRBLBR"
Hi Rex, if you get this on your display please give us a call so that we can walk you thru this diagnostic, you can reach our Product Support Team at 800-229-1687 as they are here 24/7 ready to assist, Thanks, JT
Grand Canyon Tech
Grand Canyon Tech
