I've replaced the T-con board but have the same problem. Could it be the LED driver. Any suggestions?
SOURCE: Samsung TV goes Black but keeps sound
you will need to check weather the 24vdc supply for the inverter board is good no drop voltage. if no supply check the power supply board. then you should check if their is a inv_on signal at the power inverter board around 3v-4.4vdc . if goes out during power on tried to disconnect the supply going to the inverter board to ensure if their is a shorted parts in the inverter board. if the inverter_on signal also goes out even with out inverter board connected that was mean you have problem in the processor board.
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
SOURCE: 47' (sic) LED TV, model number m470vse. Why doesn't the backlight work?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
SOURCE: On my Hisense 50K23DG LED TV, I have sound but no picture.
Hisense TV's usually use PCB Boards by Vestel and not Hisense themselves, have a look at: Vestel Help If the Boards in your Hisense match this Board/Part Number format at least you'll know what to search for, replacing the power supply will not help unless the process has been incorporated into the power supply and that is not known for certain yet
Good Hunting
SOURCE: When testin a power supply or led board on tv do i test dc or ac with multimeter?
Your power supply board is working if you get audio and imgaes.
You test AC only the AC side of the transformer before the Rectifier Diodes. Everything after the Diodes will be in DC.
did you get to see any spec of backlight as shown in
LCD LED TV Repair No Image Blank Black Screen Flashlight Test How to Fix...
