SOURCE: Haze on INSIDE of HP 2610 AIO scanner glass - how to remove glass?
with the 2610, on the right side remove gently the coverplate and then slide the under panel down. There are four places it attaches to the printer case one at each corner approximately. you can try to do what I did and use a greenie flathead screwdriver to pry it free, or do the not so obvious but much easier and kinder to the machine version of pushing it down to get the L shaped plastic pieces to release from the upside down L underneath. then there are three size T10 hex or star shaped screwdriver screws to release three of the four sides. I never could get the front silver fitted piece off, but was able to remove the glass. DO NOT CLEAN WITH WINDEX...IT LEAVES RESIDUE. USE VINEGAR. ALSO, USE WHITE GLOVES AS any dust you get on it cleaning it will leave small fibers on both sides. I used a special glass cleaning rag and then gently replaced it. note which side the black strip goes when you remove the glass!
SOURCE: HP J4580 driver for windows 98sec
Hey,
here are all the drivers available for your product, im afraid that windows 98 is no longer supported as its 10 years old
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=ie&product=3645100&lang=en&
Let me know if you need anything else.
Thanks,
Ekse
SOURCE: My faxes would not feed straight.
Refer the link below. you will be able to fix the blue plastic piece
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01110425&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
SOURCE: hp j4580 scanner not working properly need help.
If you technical. Open glass top . Check the slides, clean it with clean cloth an reconect. Will be fine.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
