Removed from console and put back in.... now intermittant on and of and on again... about every 3 seconds or so....
SOURCE: As soon as I put the volume more than half ,the
http://www.fixya.com/support/r2656152-amplifier_going_into_protect_mode
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
SOURCE: Television randomly switches off and then back on
You have a cracked solder joint on your TV circuit board. Only if you are competent to do so, the circuit pcb needs inspection and the offending joint resoldering. This is usually around the power supply area and the Line output transformer. If not competent to carry out the inspection, get a qualified TV engineer to look at it. Hope this helps :)
SOURCE: hard drive removal and put back for PS 3
If you are thinking of changing your hard drive for a bigger one it becomes a little more difficult.
However if you want to just remove it and put it back, its easy. On one end of your PS3 there will be a small cover which is prised out. Under that is a little blue screw. Take this screw out and there is a little metal pull out clip that is attached to the side casing of your hard drive. Pull the clip backwards and your hard drive will slide back. You can then remove it from the PS3.
SOURCE: audiovox 2 way family radio charger (for 4
It sounds like you have some corrosion on the terminals. Remove the batteries and with a good light source look at the springs and plates to make sure there is no corrosion. If there is remove it with crocus cloth. Check the batteries also for corrosion. If you find any remove it the same way. If after cleaning everything the batteries still will not charge get new ones as you probably have one or more which are shorted.
Thanks for using FixYa and for the generous rating.
hardrocko
