Cars & Trucks Logo
r
ray adams Posted on Aug 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have accel 566 plugs what is compatable?
I have a chevy 350 engine I think my motor is a 73
Steve P
Level 3:
  • Cars & Trucks Master 3,912 Answers
  • Posted on Aug 22, 2017
Steve P
Level 3:
Answers
3912
Questions
5
Helped
1307814
Points
15904
Champion = RV12C
Champion = RV12C6
NGk = BR5FS
NGK = BR5FS15
http://www.jegs.com/PDFs/111-UGroove.pdf
I'm wanting to upgrade a 1987 Chevy pu 350 to serpentine belt assembly. I have a 1994 chevy sbc will the 94 assembly fit the 1987 motor?
It is possible to upgrade a 1987 Chevy 350 engine to a serpentine belt assembly using parts from a 1994 Chevy small block engine. However, there are some differences between the two engines that may affect compatibility.
One major difference between the two engines is the placement of the alternator. On the 1987 engine, the alternator is typically mounted on the driver's side of the engine. On the 1994 engine, the alternator is typically mounted on the passenger's side of the engine. This means that the brackets and pulleys for the serpentine belt assembly may be different between the two engines.
Another factor to consider is the number of pulleys on the serpentine belt assembly. Some 1994 small block engines were equipped with additional accessories, such as air conditioning or power steering, that require extra pulleys. If your 1987 engine does not have these accessories, you may need to modify the serpentine belt assembly to remove the extra pulleys.
To ensure that the serpentine belt assembly from the 1994 engine will fit your 1987 engine, it is recommended that you compare the parts and brackets from both engines side by side to identify any differences.
Can a 1995 gmc 350 block and heads interchange with a 1988 chevy 1/2 ton 350
You will have to look for yourself with this picture. I don't think that'll fit example:
1-valve cover.
2-engine oil pan seals and gasket.
3-The rear block for the transmission.
4 Engine support bracket.
There are so many differences.
Hope it helps. Good luck have fun.
Ok I am wondering if my motor in my 91 gmc 5.7 l b8 is a vortec or a 350 it has throttle body carb and not sure thought if I could interchange it with an older 350 ..
Here, is what I think you are asking. The TBI intake from a 91 will fit the same size engine from 88 to 95. The Vortec didn't come out till 96 I believe. So if your 91 is the original engine then it is not a Vortec motor. If you want to swap your 5.7 with another 5.7 (5.7 = 350) Then the 88-95 should work, Just double check your sensors and locations as the plugs may be different and or in different locations. I know my 88 GMC and my 94 chevy (both K1500's) were a little different. Hope this helps.
2answers
What year is this engine? and ci
From this chart - I think you may be misreading the number - 3970010 is possibly the actual number: Which makes the engine pretty old 68-72 350 V8 - 4 bolt main. I included past this number so that you can see that the number you posted doesn't actually exist. And thus my conclusion that the 9 is most likely a 0. Hope this helps. 3970010 350 69 Corvette late 69,4 bolt main 3970010 302 69 Camaro Z/28,Late 69, 4 bolt main 3970010 350 69-79 Truck 2&4 bolt main 3970010 350 69-79 Pass,Chevelle,Camaro,Nova,MonteCarlo 2&4 bolt main 3970010 350 70 Corvette 300,350,370 HP 4 bolt main 3970010 350 71 Corvette 270,330 HP 4 bolt main 3970010 350 72 Corvette 200,255 HP 4 bolt main 3970014 350 69-77 Pass,Chevelle,Camaro, Nova,MonteCarlo 2 or 4 bolt main 3970014 350 69-79 Truck 2 or 4 bolt main 3970014 350 72 Corvette late &undefined;72,200 HP,255HP 4 bolt main 3970020 307 68-73 Pass,Chevelle,Camro, Nova 3970020 307 69-73 Truck 3970024 307 69-73 Pass,Chevelle,Camro, Nova,Truck 3992386 327 68-69 Pass,Chevelle,Camro, Nova,Truck Large Jounal
I am swaping out 1990 4.3 chhevy sport and putting i a 1995 350 chevy
The 1995 350 is a "Vortec 5.7" motor if I remember correctly.You will have to get a throttle body and intake manifold for an older 5.7 liter(early 90's?).The Vortec engines are a sequential multiport injection setup(totally different).
I can't get my '69 chevy 350 to start after rebuild.it is getting fuel and fire.but i can't seem to find initial timing to start it.It has new accel hei vacuum advance dist.,accel super coil, edelbrock...
Have you looked down inside the engine were the dist. goes ? If you do you will see the oil pump drive shaft . You will notice a slot cut in it , now look at the bottom of the dist. shaft . You will see a key or it looks like a standered screw driver . Probably not linning up , need to take a long screw driver an turn the oil pump shaft till they do .
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
