SOURCE: kenmore elite refrigerator error code er if
Bad icemaker fan. When looking in the freezer, its the one on the left.
SOURCE: Kenmore Elite Trio electronic panel displays 'Er IF' and touch buttons not working
I have the same problem!
How to remove the speaker from a Kenmore Elite Refrigerator.
Our Kenmore Elite fridge has been beeping since we bought our house 9 months ago. There's nothing apparently wrong with it, the filters have been replaced etc. Sears said it would be a minimum of $300 to replace the electric panel (and my thought was that whatever is causing it could happen again!). We were ready to buy a new fridge.
Tools:
thin spatula or hand held flat razor (for scraping paint)
flat screwdriver
soldering iron
I pried open the water dispenser with a razor thin spatula (i began with just my hands). the electronics then turned off. When the dispenser came completely off an electronic board dangled down.
On the board is the word 'buzzer' with two soldered points, underneath was a round black object, obviously the speaker. My husband and decided that if we pried the speaker off with just a screw driver, it may break the whole board. So we got out the soldering iron and one at a time, heated both soldering points labeled "buzzer." As each heated we used the screwdriver to pry the speaker off the board.
The speaker gently slipped off the board into our hands. We placed the board back in its place and snapped the water dispenser cover back into place. The whole thing took 2 minutes. The electronic lights all came back on the dispenser. Everything works perfectly. There's one less beep in our house!
SOURCE: Kenmore Elite Oasis HE top loader has LD error code
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
