Televison & Video Logo
R
Ray dela plaza Posted on Aug 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix no sound audio on Panasonic viera when connected from hdmi 3 port to Sony bluray BDP s480 hdmi port?
Joe Ball
Level 3:
Master:
  • Master 591 Answers
  • Posted on Aug 19, 2017
Joe Ball
Master
Level 3:
Master:
Answers
591
Questions
Helped
165724
Points
1736
Well, first make sure you don't inadvertently have the "mute" control on your DVD player turned to the "on" position. Does it work on HDMI 1 or 2? Play with it a bit. Connect it to other TV HDMI inputs and see what happens. Obviously, the video is getting through, just not audio. HDMI inputs on your TV carry both (unless there is a problem with one of them), as does the HDMI output on your Blue ray. Also, make sure the HDMI OUTPUT from your DVD is connected to the HDMI INPUT of your TV.
3 Related Answers
Keith Miller
  • Posted on Nov 20, 2008
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Anonymous
  • 57 Answers
  • Posted on Feb 24, 2010
SOURCE: My new BluRay player has HDMI output for both
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
ekmoetweet
Nolan Brunsdon
  • 124 Answers
  • Posted on May 11, 2011
SOURCE: I have a ProView TV
Check your sound settings on the dvd player should be pcm
Turn off dvd player and tv and make sure tv is turned on first
I just bought a Sony sound bar ht-st7 I have a Panasonic tc-p50vt25 tv and and a Panasonic blueray player these products don't have ARC. I have been using the red white cable connected to my cable box the...
Your TV does support Audio Return Channel (ARC). Try connecting your Bluray player to HDMI 2 and your sound bar to HDMI 1(ARC). You will need to make sure that VIERA link is turned on in the Setup menu of the TV.
Connecting sony viao to panasonic viera
try connecting through HDMI port on your laptop or use a VGA to HDMI converter or Connect with Wifi
1helpful
I have bought a new Blu-Ray player, a BDP-S570, which I am trying to connect to my LG TV. The TV is a 50PX4D and has one HDMI port that I have previously used to connect a Sky HD box to with excellent...
There are no compatibility issues. In your BluRays HDMI audio settings set the audio out to PCM instead of bit stream.The TV cannot decode digital bit stream audio.
Hello, I just purchased a 3D BD SONY BDP-S470 and i connect to an amplifier Yamaha RVX-3800 and this to a Sharp LCD LC-60LE925UN. When I play a 3D movie the BDP-S470 informs me that the movie can...
You need to run optical cable either from tv audio out or bluray audio out to Yamaha to get bluray surround sound, I'm afraid, there is no other choice/ option.
Thanks.
How can i connect the system to a new sony bluray
use your tv as a common connection in your theatre system. Connect your hdmi blue ray player to the tv,connect the audio output of your tv (rca style cables -red&white) or if your tv and audio system has optical you can use that also.
1helpful
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Audio drop outs when using HDMI connection on new Viera
The way I solved it was to go into advanced settings and change the audio input connected to the hdmi port to component. I had to run an audio cable from the cable box into the TV but since I did this we haven't had the problem.
2helpful
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
