Watches Logo
Jane Gough Posted on Aug 18, 2017
I have an Anne Klein watch and need a new strap. Where can I find one?
3 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 19, 2008
SOURCE: Change ******** Anne Klein watch
Your watch comes with interchangeable bezels, not faces. Bezel is a ring or rectangle (depends what shape your watch has) surrounding a glass.
All bezels are mostly friction fitted,so, to remove your bezel you need to use a strong knife blade and press it between the bezel and the case. The bezel should lift up.
To get the bezel back you have to press it into place.
For changing the strap you have to turn watch upside down and using the knife or lug tool try to squeeze sprigbar end out of the watch lug. Sprinbar is the piece which holds a strap attached to watch. The end of springbar you will find exactly where the strap is attached to watch. Push it inwards and it must come out. The rest is like 2x2.
Good luck.
Anonymous
  • 110 Answers
  • Posted on Nov 05, 2009
SOURCE: A glass for Anne Klein watch
There are sources that I use to find a replacement crystal for your watch. But even if you had a new crystal your have to know how to remove the old one and how to properly install the new one. I have the expertise and tools to do this, but it would be hard for you to do. My suggestion is to get an expert to do this, otherwise you will wind up with a watch that is not properly sealed to keep moisture out and this is the biggest killer of a watch.
uyhjgbetrw
Donald
  • Posted on Jan 12, 2015
SOURCE: Need extra link for an Anne Klein 10-7977MPTT watch
Yes you can, go to amazon and take a look: Amazon com Anne Klein10 7977MPTT watch link. Wish you best of luck.
Cheers
How to adjust Time and Date on Anne Klein 10/7899 6P05 Ladies Watch
You need to pull the crown out 2 clicks and rotate to set time.
1 click and rotate for day/date functions.
Push in fully to lock settings and resume time keeping.
Nordstrom provides a generic Anne Klein manual here:
http://i.nordstromimage.com/images/default/shop/image/misc/watch-manuals/anne-klein/anne-klein.pdf
How do I set the date on an Anne Klein watch with only a stem?????
-GB&q=anne+klein+watches+how+to+ http://i.nordstromimage.com/images/.../watch-manuals/anne-klein/anne-klein.pdf .
Hello, you can download a pdf instruction sheet at the above site. Hope it helps. Bye.......
I have a Anne Klein watch (purchased in 2002) that looses time. I have replaced the battery. The literature that came with the watch says ""This Anne KLein watch is warranted to you, the owner,...
Yes your watch is covered for workman ship and loosing time is an issue in the watch. On your warranty card should be either a
e-mail address or a phone number to contact them. Call or write to them and ask how to get warranty work done. I am sure there customer service will take care of you.
1helpful
Need extenderfor Anne Klein watch model 10/8031 SVGY.
I would recommend going to a watch repair shop for this. Depending on the style of bracelet there are a couple solutions. I would suggest a shop familiar with or that carries Anne Klein.
Most repair shops will have extender links and clasps. If you have a fashion watch that doesn't have a typical clasp or bracelet set up a Anne Klein dealer will be able to better assist you in getting a solution from Anne Klein.
Precision Time has Anne Klein and they do a fair job of getting parts through their repair center. You can visit their web site at PrecisionTimeCo.Com.
Sep 22, 2009 • Watches
1helpful
Anne Klein 10/5875 Y121E
You do noy need an exact Anne Klein band as all watch bands are made to specific measurements.
You have to measure the width of the band (the end attached to the watch) and buy any type of band you like, just make sure it is exactly the same width as the previous band. In case if you have the Anne Klein clasp or buckle, you have to measure the other end of the band as well and by any band you like, but in this case you need to match both ends of the band. Clasp or buckle are easily refitted to the new band and nobody knows that this is not an original one.
Do not forget to rate, please.
130helpful
5answers
Cheers
2helpful
Good luck.
Top Anne Klein Watches Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Anne Klein Watch Expert? Answer questions, earn points and help others
