No household electrical or wiring issues. i have emptied it, and have even rinsed reservoir in case a float valve or some other sensor was stuck thinking it is full.
SOURCE: Blinking bucket full light and humidity setting stuck at '01%'
yes but i might be late. if you still have this let me know
SOURCE: LG LHD45EL
The temperature sensor on teh suction return line from the coil has drifted out of spec and needs to be replaced. This sensor is part of the sensor assembly which plugs into the control board. I purchased the part from Appliance Factory Parts on line, cost about $30, an hour or 2 to change depending on your mechanical level, it is easy to do. For Goldstar DH404E part # was 6877A30013M, they are same part for many models but if this is not the right # for your model just get the right "sensor assembly" for your model and change it out. It consists of Temp/humidy sensor in coil, temp sensor in suction return line, and plug harness that goes to float switch. My uni is running like new again.
SOURCE: The bucket full light blinks even though it is
Take out the bucket and locate the bucket full switch inside the cabinet. Depress the switch and see if it comes on. If so, you may have to add a shim to the bucket or strap it in with a bungie cord as the bucket is jiggling and makes the unit think that it has been removed.
SOURCE: Unit will not run.
Error code 01 - unit has a sealed system leak; most warranties are 5 years.
Testimonial: "Thanks, this information was helpful in helping to make my decision on whether to pay the $29.00 service fee to diagnose the problem. "
SOURCE: My LG Dehumidifier model LHD45EL stopped working.
Here
is a tip that explains what can be happening to make the dehumidifier
show that the bucket is full when it is not.
Dehumidifier
Problem It shows Bucket Full
heatman101
