SOURCE: 1989 chevy 350 automatic, white smoke
white smoke is antifreeze try checking the compression
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
SOURCE: I have a three year old Piaggio 50cc Zip scooter.
I have had the same problem with my stepsons zip 50 and have done all the usual checks. The solution is from a piaggio technition. Take off the air cleaner and housing, start the scooter and bring it to the point where the engine dies. At this point spray easy start or a gasoline spray direct down the carb intake. If the revs pick up, you have a lack of crank case compression and the most likely reason is worn oil seals on the crankshaft. It sounds odd but the worn seals cause all kinds of strange problems.
Thats 2 stokes for you. Hope it helps, good luck
SOURCE: Chrysler 70 HP outboard motor dies when pushing throttle
I have found that 99 percent of the time when this happens it is carb related. It is very possible that you picked a a small piece of grit or trash in the high speed jet of one, or both, of your carbs. I would be willing to bet that pulling the carbs and cleaning them will resolve your problem. I am almost positive that will fix your problem, mainly because it sounds like you've already tried everything else. I had this same problem last season, and what had happened was I left the vent open on my fuel tank, we got a shower, and I pulled just a small bit of water into the carb and that was it, she would not do anything over idle until I pulled the carbs and cleaned them. i even put the water muffs on it and let it run in the yard for about an hour thinking that it would burn the water out, but i was wrong. Anyway, clean the carbs and i think you'll be in good shape, Good Luck.
SOURCE: motor chokes and misses under moderate load and loses power
Sounds to me as tho it might need a carburetor adjustment, providing there is an adjustment screw on the carb. Sounds like the engine is running a bit lean. Did this problem occur right after the carb cleaning, or was it there in advance? Is there a fuel filter that might be clogged?
