Kitchen Appliances - Others Logo
C
Claire Dupuis Posted on Aug 17, 2017
User guide for rice cooker
Black & Decker model RC3406 type 1
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jan 08, 2010
SOURCE: I need a manual for the Black and Decker RC3406
I ran into the same problem locating this manual. Black and Decker hasthe manual for the 3 cup on their site but not the 6 cup. I did find amanual for the Rival brand version which appears to be the same thing.You can find it at the URL
http://www.rivalproducts.com/manuals/MANUALS/RC61_43_53194273.PDF
Anonymous
  • Posted on Feb 18, 2010
SOURCE: What is a measure on the RC3406
not sure about that measuring cup thing. just use 1 part rice to 2 parts liquid and you'll be fine
Anonymous
  • 268 Answers
  • Posted on Apr 27, 2010
SOURCE: how much rice and how much water in a black and
This rice cooker lets you make up to 6 cups of rice,
Ray
  • 324 Answers
  • Posted on Jun 20, 2012
SOURCE: Black & Decker 6-Cup Rice Cooker with Steamer Basket rc3406 manual
Try here and scroll down to your model number.
or try direct link
Testimonial: "Thank you you found the Black & Decker 6-Cup Rice Cooker with Steamer Basket rc3406 manual. David N"
mbarre
  • 937 Answers
  • Posted on Jan 08, 2015
SOURCE: I need lid for Black and Decker RC-400 Type 1, 8 cup rice cooker
Here you go: $13.62
Black and Decker RC400 Rice Cooker Parts
can also try eBay
I am trying to upload manual for 6c rice cooker and steamer, I just purchased it and there was not one in the box. Doesn't seem to want to load, can you email it to me .
A manual for the Rival RC61-CNcooker which is identical and made by Black and Decker is at:
2helpful
I need cooking instructions for RC3406 6 cup rice cooker and steamer
Since a steamer is a steamer, try the following suggestions:
White rice: 1 cup to 2 cups water for 45-50 minutes.
Brown rice: 1 cup to 1.5 cups water for 45-50 minutes.
Hope this helps!
Do you use hot or cold water. It doesn't say in the manual
I have used both hot or cold water....but have found that hot water works best to rinse the starch off and also makes the cooking process go faster...
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
2helpful
Lost the rice measurer, how much is 1 rice measure in cups please?
About 2/3....
heatman101
1helpful
Lost rice measuring cup I am not sure how much rice it held
Here is a tip that I wrote that will help you with using your rice cooker to steam your veggies...
How to Steam Vegetables in your Rice Cooker
heatman101
RICE COOKER DIDNT COME WITH MANUAL DONT KNOW HOW TO USE IT NOR HOW TO MAKE RICE WITH IT HELP PLEASE THANKS
Not sure about your model but most work the same way. Measure a small cup of rice for each person and add the same amount of water. Water should cover the rice by about three quarters of an inch. Close lid turn on and let it do it's work. When it has finished, leave it alone for about 20 minutes for the rice to steam. It will stay hot, don't worry. Then fluff up rice and serve.
1helpful
The swith is not working and no light is coming in the cook or warm mode.
first try to remove the pot, then push the button in middle of the ricecooker..if th cooker light turn on then the problem is the spring..try to open your rice cooker, you will see the spring inside, try to stretch the spring
2helpful
Top Black & Decker Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
