1977 Shovelhead Electra glide signal lights went out.
SOURCE: I have a 2007 Electra glide Ultra Classic. The cruise will not e
You may need a new ECM module .
SOURCE: GMC Envoy 2002. When I get to traffic stop light.
check your vaucumn hoses for leaks any leak in that system will effect your fuel pressure regulator and fuel rail that controls the running ability
SOURCE: i have a red key light and I have lost my turn
your problem is common, disconnect your ciggerette lighter untill you can repair or replace the short curcuit...
SOURCE: turn signals will not work on 1991 electra glide
The clicking you hear may be an add-on module that makes both rear turn signals into brake lights. Remove the seat, locate the clicking module and remove it, it should be about 2.5" long and about 2" wide and 1/2" thick, then put the plugs back together w/o the module and try the blinkers. One on of the module is female the other male to help locate it, but it's one of the few connectors that are quite big under the seat. Harley sells these or they did, as well as a couple aftermarket makers. I have one on my FLHT.
